Question about Texas Instruments TI-83 Plus Calculator
How do I enter log 1.9 divided by 4 log 1.0175
I am having problems getting the correct answer to the above problem. I think that I am not entering the problem into the caluculator properly. How do I enter log 1.9 divided by 4 log 1.0175 into the TI-83 Plus?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
LOG 1 . 9 ) / 4 LOG 1 . 0 1 7 5 ENTER
Posted on Jul 05, 2010
How do you simplify the exponent on the calculator?
I assume 13m/2 is the radius of the sphere and you are trying to calculate the volume of the sphere.
The first thing we have to think of is BEDMAS, the order of operations, as some calculators do them correctly, while others do not. Let's be safe and do the BEDMAS manually so we know we will get the correct answer.
B - brackets - enter 13/2 in the calculator - hit enter
E - exponents - with the answer from the first line in the calculator, use the hat key (^) or the y to the x key to raise this to the third power (exponent 3).
M - multiply - with the answer from the line above, multiply this by pi or use what you are instructed to use or use 3.14159, then multiply by 4 and divide by 3.
You should have your answer.
Good luck.
Paul
Jul 12, 2015 | Office Equipment & Supplies
Dividing a number by Avogadro's number. It is not working. Do I need to change some setting?
Nothing of the sort. Just locate the EE key. You access it by pressing [2nd][x^-1]. It is the one below the [sin] function key.
To enter Avogadro's number
Key in
6.02 [2nd][x^-1] 23 [=/Enter]
If you divide by that number just enclose it between parentheses to ensure correct calculation.
You can also enter it as described 4 lines above, press the = key. The number will be displayed. To divide by it, press the [x^-1] key and its reciprocal will be displayed ready to be multiplied.
Oct 30, 2013 | Texas Instruments TI 30XIIS Scientific...
When i enter 30xlog(1/2)83/8000 i get -0.09395586 and the answer is suppose to be 336 what am i doing wrong
That's the answer I get for
30 times log of 1/2 times 83 divided by 8000
or
30 x log(1/2) x 83 / 8000
Are you sure you have the problem specified correctly?
Dec 07, 2012 | Texas Instruments 30XSMV/TBL TI-30XS...
Log 10,000 - log 1,000 divided by 4 log 1.0125 = 46.34 I cannot enter this into my calculator and get 46.34 as in the example. is there a trick in the way to enter this? I have a TI-30X calculator....
Is the original problem (log 10,000 - log 1,000) / (4 log 1.0125) ? If so, press
( 1 0 0 0 0 LOG - 1 0 0 0 LOG ) / ( 4 * 1 . 0 1 2 5 LOG =
and you should see the expected result.
Jul 25, 2011 | Office Equipment & Supplies
TI-84 Plus Silver Edition. When dividing negative powers of ten by other negative powers of 10 the calculator it just adds the the negative powers together. How do i fix this? An example: 5*10^-10 /...
To enter an exponent, positive or negative, use the EE (Enter Exponent) key (the shifted function of the , key just above the 7 key). Do 5 2ND [EE] (-) 1 0 / 5 2ND [EE] (-) 1 0 ENTER and you'll see 1.
What I think you're doing (I can't be sure without seeing your keystrokes) is calculating
5*10^-10/5*10^-10 which is interpreted as (5*10^-10/5)*10^-10, which indeed is 10^-20.
Oct 16, 2010 | Texas Instruments TI-84 Plus Silver...
My problem involves converting in chemistry and im just trying to figure out how to do a problem 0.58 x 6.022 x 10 raised to the 23/ 1. I know how to calculate the problem just cant read the answer a more...
Press the keys:
. 5 8 * 1 2 . 0 1 x^-1 * 6 . 0 2 2 2ND [EE] 2 3 ENTER
and you should get 2.9E22. Do you get something different?
* is the multiply key on the right, between divide and subtract.
x^-1 is on the left, below MATH.
EE is the 2ND function of the , key, just above the 7.
Another way to calculate this is:
. 5 8 / 1 2 . 0 1 * 6 . 0 2 2 2ND [EE] 2 3 ENTER
This should give you the same result.
Mar 10, 2010 | Texas Instruments TI-83 Plus Calculator
Entering 6.02 X 10^23/ 206 =
I think I'm reading this correctly. In your exponent, you are dividing 23 by 206. If so, enter in the calculator the following way:
6.02 x 10 ^(23/206) and then the enter/= key. You should get an answer of 8. The ^ key is 4 keys above the "on" key. You must use parentheses around the fractional exponenet
Aug 07, 2009 | Texas Instruments TI-30XA Calculator
How do i perform the calculation of log (base 2) 8? The answer should be 3....that is it is the inverse calculation of 2 cubed =8. Can any one help with the log calculation?
Yes look you can't enter the base in calculators it's default 10 so use:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
so instead of log 8 base 2 input log 8 / log 2 it's easy
hope you understand :)
Feb 21, 2009 | Sharp EL-531VB Calculator
Mixed numbers
Proper fraction e.g. 3/5, input 3, divide, 5, =, answer 0.6
Improper fraction, either enter as improper fraction, or enter the whole number first, then +, then the proper fraction as before, then =.
E.g. 8/5 which is "1 and 3/5': enter 1, +, 3, "divide", 5 =, answer is 1.6
Or, just 8, "divide", 5, same 1.6 answer. Why go to mixed number first?
13/5 which is "2 and 3/5", enter 2, +, 3, "divide", 5, =, answer is 2.6. Or, just 13/5, same answer
Dec 17, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-83 Plus Calculator Logo
123 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
