Question about Electronics - Others
When I put a jumper in the eleven and one position on the 7 point electrical connecton in my canyon Trail 5th wheel the parking lights do not come on as they have done in the past? Cannot find a blown fuse
    Champion:
  • 225 Answers
Sounds like bad ground,it is possable that both bulbs are blown.take a hot jumper right to the lights them self,see if they come on and work your way back to the plug.
Posted on Jul 10, 2010
Key stuck in ignition car stuck in park key won't go to off position
There may be to much pressure on the steering wheel lock for it to go into the off position. put the parking brake on. put the shifter in neutral gently turn the steering wheel in the opposite direction of where the wheels are pointed and try turning the key to the off position. Good Luck
Sep 03, 2016 | Cars & Trucks
What is the function of the 8 wires for the factory rv plug?
The 8 wire plug on newer models is for trailer hauling. The wires give power to the following; break lights, marker lights, backup lights (as equipped) parking lights, electric breaks (larger trailers will have these) one wire is a ground, and, through a positive wire, will trickle charge your trailers house batteries also. There is an industry standard to wiring one of these plugs, so you should be able to purchase any "newer" style trailer (tent, tow behind or 5th wheel, or camper) and the wiring harness will be wired accordingly. Any RV shop or auto shop should be able to provide a schematic for the wiring if you require one.
Aug 05, 2011 | 2001 Dodge Ram 1500 Truck 2WD
I have windows 7 and when i tried to install Oregon trail 5th edition on my computer, it said wasn't compatible and that the disk was never located.
right click on the setup file select properties then the compatibility tab set the compatibility to windows xp sp2 and check the run as administrator box. The setup file will be somewhere on the disc and will be a .exe or .msi
May 11, 2011 | The Learning Company Oregon Trail 5th...
How do I give a jump start to another veichle?
Your jumper cables are most likely red and black. Locate the positive and negative terminals on your battery, they are marked ( + ) or pos.,that's the red one, and ( - ) or neg. that's the black one. Conect one end of your cables to your battery (doesn't matter which one you do first) make sure you are connecting the other end to the same terminal on the dead battery (that is to say positive to possitive) now do the same with the other cable. There may be a little bit of a spark that's normal when you make the final connection. The danger is in taking them off, do it in the same order that you put them on, if you take both cables off at the dead battery and they touch you are going to be having a bad hair day. the thing that most people don't get is you have to have a good clean convention. If you don't try wiggling the clamp on both batteries to make them dig into the terminals. Also there is a huge difference between someone who left the lights on in parking lot and someone with a dead battery on the side of the interstate. The guy in the parking lot has a dead battery, the guy on the side of the road has a dead battery and a dead alternator, he needs a tow truck, not a jump.
Jan 25, 2011 | 2006 GMC Canyon
The bike was running fine in the evening. Rode to work parked the bike took the key out. The battery was dead in the morning. Put the 10 amp charger on and the motor started to turn over with the key off!...
your starter button is malfunctioning. maybe some oxidation in the switch. when starter button is pressed in that can cause your other electrical stuff to not work.
May 16, 2010 | Motorcycles
Have a 2005 Titanium 5th Wheel.12v lights flicker when on shore line. Any suggestions?
Do you run a inverter? Or have a 120 vac to 12 vdc system. This does not sound like a ground problem with the 5th wheel. But you can use a jumper cable and hook around the 5th wheel to check that possibility. Sounds more like a loose connection at the junction box of your RV or a problem with the Inverter.
Mar 30, 2010 | Computers & Internet
Oregon Trail 5th Edition not working.
either keep putting the 2nd cd / dvd else. search both cds u'll find put the same exe file image ( a patch ) same as the file image on which u double click n run ( just copy that file into the location and it ll be done.
Feb 25, 2010 | The Learning Company Oregon Trail 3rd...
Electronics - Others Logo
170 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
