Samsung hl-s4666w dlp won't come on... - Televison & Video
  • 5 more comments
  • jtpaul Apr 18, 2008
    What happened is about a week or so ago, the tv would be on for about 20 minutes and shut off. I would turn it back on and it would go 20 minutes (or so) and shut off... Now all three lights are blinking and it clicks when i turn it on, but no sound or picture... Looked at the bulb, looked fine, but...... Please help.....
    as described above...
    no manual.. repair-wise that is...
    nothing on screen... just green lamp led blinks, then clicks, then red standby/temp blinks, then all three blink together...
    I have the above described dlp and it started to not work about a week or so ago... First, it would be fine, then after about 20 minutes, it would lose picture (still have sound), then shut off... I would turn it back on, only to have the same result. Now, it has gotten to where it won't come on (all three lights are blinking on the power button)... I checked the bulb, it "looked" fine, but...... The bulb has been replaced twice in 2 years and the tv is out of warranty...Can you help????fine, but...... The bulb has been replaced twice in 2 years and the tv is out of warranty...Can you help????
    Lamp blinks 17 times... Holds, then all 3 start blinking...
    Brigadier General:
  • 6,966 Answers
If I may add to the other postings....
Is there any particular sequence or number of blinks/flashes of the LEDs (lights?
Posted on Apr 18, 2008
    Genius:
  • 3,422 Answers
HI,
Can you please give more details on your problem so that i can help you fix it.
Waiting for your reply.
  • Priya darshan Apr 18, 2008
    Hi again,
    If you hear any click sound then these are the following possibilities:
    ONE: The protection circuit is shutting the set down when you turn it on - to avoid further damage to the set.
    TWO:
    The reason for the shut down is due to the protection circuit detecting
    excessive current in one or more sections of the tv.
    THREE: The
    clicking sound is the ON relay getting shut OFF by the protection
    circuit. The thumping sound in the speakers is from the power supply
    coming up in voltage a little, and then shutting down.
    FOUR:
    Number one reason for auto shut down in big screens is loss of high
    voltage. Number two is defective deflection amplifiers (horizontal or
    vertical amplifiers).
    FIVE: These repairs are not something you can do at home; they require the service of a trained tv tech.
    You can cooperate with IB4G2008
    Goodluck,
    Please don't forget to rate the solution.
    Genius:
  • 3,587 Answers
Hmmm..not too cool..check all cables, and power source first, yes?
  • Patrick Michaels
    Patrick Michaels Apr 18, 2008
    do you have a manual for this by chance?
  • Patrick Michaels
    disconnect all input cables..turn off..then on..and tell us what is on screen
White Dots, 13 in past month, what's going on...
you have many white dots in your tv screen but you can stil see the picture if this is your problem your dmd chip is defective this will be very expensive to repaire and to complicated this needs to be repaired in a repaire shop
Oct 29, 2011 | Samsung HL-S4666W Television
Tv repeatedly starts at and shutts down. Lamp come on but then shuts down
Those lamps build up a internal resistance and they get to the point where it will not come on at all, replace the lamp, and you will be good.
Oct 18, 2010 | Samsung HL-S4666W Television
Samsung hl-s4666w DLP "Check Fan #2" on-screen message appears before shutting off. How do I fix this?
Look at the Large Lamp fan and if it is not rotating it is bad and needs to be replaced. If is ok then check the other two smaller fans. You do have a bad fan.
Apr 03, 2010 | Samsung HL-S4666W Television
My HL-S4666W's screen picture freeze whenever I turn it on
If the tv has a built in discoder, it is the decoder at faulty, bypass the decoder using a dvd player, and if that plays then it will prove the decoder fault, the dvd signal is stronger than an external source, oh, by the way, unplug any source of dish/arial etc to the decoder, giving the dvd master control of the tv
Jun 07, 2009 | Samsung HL-S4666W Television
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
56" screen dlp Samsung
You can find a new Samsung replacement Lenticular screen and fresnel screen for a model # HL-P5663W from a major Samsung distributor at the following links:
Samsung HL-P5663W Replacement Part Fresnel Screen
Samsung HL-P5663W Replacement Part Lenticular Screen
Feb 12, 2009 | Samsung DLP HL-P5663W 56" TV
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
SAMSUNG DLP MODEL HL-S4666W
Bad capacitors on the power board. Yes you can do the repair yourself.
Sep 07, 2017 | Televison & Video
Samsung hl-s4666w won't come on...
Circuit malfunction indicated. Have it serviced
Apr 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
