Question about Averatec 3200 Notebook
Processor issue? bios/motherboard?
The laptop powers on fine. Fan rotating as long as its powered on. Even the cd-rom shows signs of activity(blinking lights). But no reaction from the hard drive. Doesn't boot to bios. Nothing on the lcd screen-eigther not even the averatec logo (total blankness). Doesn't detect keyboard/mouse(no lights on caps lock etc.). Memory is good, beeps when ram is detached. help?
  • confusedjack Apr 18, 2008
    thanks, i'l try that. but even if the hard drive is defective shouldn't it still post, show the logo and enable access to bios? all I see is a blank screen
    Genius:
  • 1,027 Answers
First, Pull the hard drive. If the hard drive shorts out it can cause all sorts of problems. Generally it detects Hdd before mouse and keyboard.
Posted on Apr 18, 2008
  • Mark Williams
    Mark Williams Apr 19, 2008
    If the hard drive is shorted there will be no activity, no post no error and possible damage to the board.
Just now i shut down my computer normally, an hour later when i tried switching it on again i cannot, the monitor dosent show any image, it even not shows the BIOS, the fan tuns just for a while and then...
It sounds like a hardware problem. Check the obvious like the power cables and plug it into a different wall socket to make sure that isn't the problem.
Does the computer beep when it starts up. The pattern of these 'POST' beeps can help you determine the problem. However if the computer doesn't beep, doesn't activate the BIOS and the hard drive doesn't spin up (with the HD light flickering) then you either have a fried motherboard or processor. Not an easy or cheap thing to fix.
Sep 03, 2010 | Computers & Internet
Failed to boot, i cant even get to the bios! only the fan running, led(green) and (red) indicator doesn't even light.
Dear Client, unpluged all the data cables, power cables or wires, bios cell and RAMs. Everything should be unpluged from the motherboard for two hours and then reassmbled. It will work properly but when you reassembled it just plug with the follwing devices.
* Power Cables
* Data Cables
* Bios cell
* Processor + Fan
* RAMs
Do not attach CD-Rom or Hard Disk, just turn on the computer without Hard Disk and CD-Rom and try to enter in bios setup. I assure your problem will be solve. Now you can attach the CD-Rom and then try to boot up from the CD-Rom and in the last you should try to attach Hard-Disk. I hope you will do it step by step and get success.
Good Luck
Feb 14, 2010 | Asrock 775i65G Motherboard
Hi, my problem on dell inspiron 1526 is this: SYSTEM MODULAR BAY cannot be indentified.... problem is that CD/dvd drive show signs of work(when i turn my computer on Green led blinks,motor starts to rotate...
If the drive functions in another system the the issue is either the motherboard contacts or the controller. Flash the BIOS to the most current version and reset the BIOS defaults. If the drive still doesn't detect, then a motherboard replacement is likely in order.
Nov 15, 2009 | Dell Inspiron 1526 Laptop
Dell D600 when powering, leds blinking
Its a motherboard problem. check all the flashing codes here.
CLICK HERE
it will give you all the information about the codes.
Sep 26, 2009 | Dell Latitude D600 Notebook
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Hank
Aug 17, 2009 | Intel D865GVHZ Motherboard
Acer Aspire 5520 boot problem power on linght blinks
If you can't get past the bios boot then likely its a problem with the bios settings or a hardware issue on the motherboard. Make sure the processor fan is running when it turns on.
Feb 23, 2009 | Acer Aspire 3100-1405 Notebook
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Averatec 3200 Notebook Logo
283 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
