Question about Gibson Thru-Wall/Window Air Conditioner
I have 2 Gibson AC's that are thru mounted that have worked well over the years with some water issues. WE have cleaned them without removing them from the windows with good success each year. Now, both of them are dripping water down the inside ofthe house. They both have the angle ointing down on the outside that they originally had. Something makes them both want to back up water. Can I carfully drill a hole further back to relieve some of this, or is there a better way. I think the pan on these are they type that has coolant in much of the pan for efficiency. Thanks for a rapid response. It's hot here! Larry
  • 29 Answers
DONT DRILL A HOLE! It is to easy to drill through a refrigerant line and that's big problems. Water in the bottom of the unit is normal and there is usually a water slinger on the outside fan that blows the water on the condenser coil. Its good that you have checked the slope on the unit. It seems odd that both units started doing this at the same time. The water flows whereever it can from the front of the unit to the back. Probably the units are quite dirty and need cleaned. The dirt in the corners of the pans where the coils set can stop the flow of water through the pan.
Posted on Jul 06, 2010
Testimonial: "Thank you for your insight. I was afraid to drill holes, but may have to resort to that later. I guess I don't yet know how to clean the base pan. That has NEVER been done and doesn't show in the book as a maintenance item....ugh. Thank you again. I will see if I can find a way to clean the bottom. Larry"
Water is leaking from the floor vents what could be the proble?
Check your heater radiator. It is usually mounted behind/near the glove box areas on most cars. It is like a small version of the large radiator that is mounted on the front of your vehicle under the hood. Antifreeze and coolant (does it smell a little like antifreeze?) flows thru your front radiator, thru the block and hoses, and cycles thru the radiator for your heating system. If the radiator is leaking, often it cycles thru the vents on the interior.
Another possibility MIGHT be the AC system and condensation/AC coolant that is building up in/on the lines and transferring thru the vents.
Aug 18, 2014 | 1999 Buick LeSabre
Water leaking in floor board when a/c on in mazda mpv 2001
You probably have a plugged drain outlet for your under dash heater/AC unit....system is designed to drain moisture from AC evaporator core via the drain outlet...drain outlet is located under the hood
Thru the firewall and is a (approx) 1/2" dia rigid plastic tube. Sticks thru, toward the rear of the engine, about 1". It's located so that it spills (nice!) onto the most rear engine/tranny mount. There's evident rust to prove it. Try to remove it and the water should pour out . Try to locate the drain by looking where the arrows are pointing to on the pictures I am supplying
1d4363cf-13f8-4af3-a2b2-ecb08cfd6711.jpg 8b16ada2-2a73-4695-b050-f5e63bc38830.jpg
Jul 14, 2014 | 2001 Mazda MPV
Helpline
Sounds like a cleaning problem. Mix 1/2 vinegar and 1/2 water pout into machine and brew,WITHOUT K CUP! Do 5-6 x's and then brew plain water to rinse vinegar out. Do this several times. Should be ready to go.
Mar 31, 2014 | Keurig Coffee Makers & Espresso Machines
How to remove front cover to clean evaporator coil on gibson gah12er2t
pull the unit forward almost taking it out of the wall, on top and to the sides or under there should be some screws to take off the plastic grid. before you do that please make sure there is no power to the unit.
Aug 12, 2011 | Gibson GAH12ER2T Thru-Wall/Window Air...
Why does water shoot out of my window ac. it shoots our of the vents that blow the cool air?
1) Your AC has a VERY powerful blower. 2) The intake air filter is probably really clean (if not recently washed). 3) It is extremely humid... The water is likely condensation on the evaporator (totally normal), but because the air is flowing so well and fast, it doesn't have enough time to drip down.
Jul 20, 2011 | Gibson Thru-Wall/Window Air Conditioner
The AC works but the blower fan doesn't
Hello, this could be a bad capacitor or the motor itself is bad. Try replacing the capacitor first.
May 17, 2011 | Gibson GAC105P1A Thru-Wall/Window Air...
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Sharp CV-P10NC AC unit it has a puddle of water coming down.
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Aug 17, 2009 | Sharp CV-P09FX Air Conditioner
Installing the serpentine belt
The power steering pump is only held on by two bolts that are removed thru the pulley holes. Anyway you don't have to remove the whole motor mount just remove the nut that holds the mount just to the left of the balancer. then remove the stud with a inverted torx bit. then remove the sleeve the stud went thru and then the belt will come off.
May 15, 2009 | 1996 Buick Park Avenue
Air condition cleaning
hi! there,
if your unit is almost five years from now,its more convenient to have a maintenance schedule every two to three time a year,if this a windows type,cleaning of ac unit mostly the eveporator and condenser should free from dust,upon installing,the a/c unit should be eleveted down on condenser,the tray should have a drain with hose to drip the water outside your room,so that water will not leak on your light,see this may cause electrical fault resulted on burning.have always clean the filter.try to inform the maintenance crew to elevate the condenser portion down gradually so that water will drip outside the room.have anice day,don't forget get to rate me,and thank's a lot.
Apr 26, 2009 | Heating & Cooling
Gibson  Thru-Wall/Window Air Conditioner Logo
157 people viewed this question
Top Gibson Heating & Cooling Experts
john h
Are you a Gibson Heating and Cooling Expert? Answer questions, earn points and help others
