Question about Panasonic Heating & Cooling
Should the drain plug be in or out when running a Quasar HQ2121MH window mounted A/C
  • rjermyn Jul 05, 2010
    right now it is just dripping out the bottom onto the ground. Is that ok ?
    Thanks for taking the time to answer my post!
  • 29 Answers
It should be out and connected to a drain to allow condensate to collect in the drip tray from the evaporator coil and then run away down the drain.
all the best
Posted on Jul 05, 2010
Frigidaire FRA256ST2 window air conditioner unit quit working, breaker is fine and the plug reset only gets the unit to beep but not turn on
Have you recently plugged in another appliance (computer, microwave, etc)? The drain on your home's wiring system may not be allowing all appliances to run at once.
Some basic trouble-shooting guidelines can be found at: http://www.repairclinic.com/Air-Conditioner-Troubleshooting
Jun 21, 2012 | Frigidaire FRA256ST2 25,000 BTU...
Quasar cool look hq2061fh
Hello, some window units do not use a drain tube instead they use the condenser fan blade to scoop the condensate from the bottum of the base pan and splash the condenser coil to keep the condenser cool and also evaporate the condensate. Most of the time you can hear a "swishing sound"
Jun 19, 2012 | Quasar HQ2052UH Air Conditioner
What type of refrigerent is used in a quasar hq2121mh a/c unit?
will be a great idea to get support customer, and ask the company for what type of refrigerant they recommend.
Today are many restriction, and new type of refrigerant
God bless you
May 09, 2012 | Heating & Cooling
Leaking from the bottom in the house
tilt it back more and chech the drain to be certain ti si not plugged with dirt and lint
Jul 19, 2011 | Quasar HQ2051NH Air Conditioner
Overload protection piece is burntout MRA98695
THE TRUE NAME OF THE PART IS A KLIXON SWITCH, THERE SHOULD BE NAME AND NUMBERS ON THE SWITCH SOME WHERE. MEAN WHILE I'LL SEE WHAT I CAN FIND OUT FROM THE MODEL NUMBER. IF YOU WISH CONTACT ME DIRECT AT
tstewart1956@verizon.net
Aug 10, 2009 | Quasar HQ2101SH Air Conditioner
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
My window air is leaking on the inside of my house
usually because the drain hole/duct/tube, on the outside is blocked, or the aircon is mounted leaning Into the house, condesate that is supposed to drip into the outer casing and run out the hole is funneled over the lowest point of the casing, the house side.
check and unblock the drain,
and ensure the aircon is mounted tilted back.
Aug 02, 2008 | Haier hwr10xc6 Air Conditioner
Quasar AC unit operating costs
$.1545 X 1.15 per operating hour. Depending on actual voltage it could be a little less. Computes to $.177675 cents per hour of operation.
http://www.eia.doe.gov/cneaf/electricity/epm/table5_6_a.html
Jul 03, 2008 | Quasar HQ2121 Air Conditioner
Dripping inside
You need to check the condensate drain plug. It will be on the backside of the unit either in the left or right corner of the unit.
Hope this helps Ya please rate me.
Jun 18, 2008 | Quasar Heating & Cooling
Searching for driver
driver for my quasar webcam
Dec 30, 2007 | Quasar VM-D51 Camcorder
Heating & Cooling Logo
109 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
