Question about Canon PIXMA MP170 All-In-One InkJet Printer
Display reads printer band needs realining how do we do this? it does not print properly the ink overlaps
    Scholar:
  • 117 Answers
I looked at teh service manual for this printer and could not find anything about the error message. But you might be able to fix this by going into your printers properties and mainenance tab and selecting the printhead alignment option. You might need to do a printout and then adjust the settings per the directions that the printer gives you on your computer screen.
Best of luck.
Posted on Jul 06, 2010
Anything I print looks really faded.
Did you clean the print heads and/or re-calibrate the printer after installling the new ink. It is possible, however, to have gotten a faulty cartridge.
Hope this helps
Randy
Aug 31, 2012 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Different ink settings banding
Try doing a printer head alignment, sounds like the printer heads are overlapping causing the banding.
Screen colors also never match perfectly to the print either, whist your monitor can produce millions of colors, the printer can only do some many.
Aug 30, 2009 | Epson Stylus Pro 9600 InkJet Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Dec 12, 2008 | Xerox Phaser 6110 All-In-One Laser...
Printer suddenly won't work
  • Replace a new Canon ink cartridge as it could be due to the unique features that Canon has build on their ink cartridge not done properly which resulted to be faulty. Report the issue to Canon if your existing ink cartridge is not from other 3rd party band, Canon should be able to do 1 to 1 exchange once confirmed that it is their ink cartridge problem. Cannon has build the unique feature to prevent users from misusing 3rd party ink cartridge on their printer.
  • Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
  • Or missing pin has dropped off from the print head, which causes the printer not able to read the ink cartridge, printer needs to be serviced.
  • (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
Jan 24, 2008 | Canon Pixma MP500 All-In-One InkJet...
Pixma mp500
  • Or missing pin has dropped off from the print-head which causes the printer not able to read the ink cartridge, printer needs to be serviced.
Nov 25, 2007 | Canon Pixma MP500 All-In-One InkJet...
PRINTING PROBLEM
You printer cartridges need to be cleaned,aligned properly...printer software can do that...
PLEASE RATE ME AS ( FIXYA ) <blue boxes>............
Oct 19, 2007 | Epson Stylus D88 InkJet Photo Printer
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
Canon PIXMA MP170 All-In-One InkJet Printer Logo
26 people viewed this question
old marine
old marine
