Question about HP Compaq Presario CQ60-249US Notebook
Curser will not move page up and down using touchpad i have to go to the up/down arrows on page and click
  • 518 Answers
Make sure you have the latest driver installed for the Synaptics pointing device which is what operates you cursor
Posted on Jul 05, 2010
Intermittantly the curser freezes then erratically moves around the screen by itself. I am unable to move or 'control' the curser so find it difficult to shut down to do a re-start. I usually have to hold...
Make sure that you are not placing the hand on the touchpad while typing.... This might be due to the drivers issue with the touchpad.. Try to unistall the drivers of touchpad from the device manager.. Then install a fresh copy from the dell website(www.support.acer.com).. If the issue is yet to be fixed please contact Acer to replace the touchpad....
Sep 16, 2010 | Acer Computers & Internet
I am unable to click using the mouse pad. I can only move the curser with the mouse. I have to use the left click button. I cleaned the pad, but to no avail...HELP!
  1. Click Start.
  2. Go to Start, click Run, type main.cpl in the box next to Open, click OK.
  3. Click the Dell Touchpad tab or Hardware Tab.
  4. You will see Devices connected to the Laptop.
  5. Click on the touchpad or one by one the devices.
  6. Click Properties.
  7. At the bottom of the window, check & select from the drop down list Enable/Disable the device.
  8. Click Apply, then click OK.
Aug 20, 2010 | Dell Inspiron B130 Notebook
Toshia A135-S4527 that goes blank after account login
Press Ctrl+Alt+Delete, the Task manager will appear. Click File, click New Task, type explorer, OK and it should start.
Jun 20, 2010 | Toshiba Satellite A135-S4527 Notebook
Touchpad seems stuck. Can move curser, but cannot
Does it pop up? or you just can't click try hitting it really hard...
my right click is broken permanently but still pops up
Oct 25, 2009 | Sony VAIO FX215 Notebook
Acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Jan 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Erratic curser, jumping
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for mice and pointing devices, click the '+' sign and right click on your touchpad and select uninstall, do the same on the keyboard line and then restart the pc.
Both touchpad and keyboard will be reinstalled and then ready to use again as it should be back to normal
Sep 10, 2008 | Dell Inspiron 6000 Notebook
Touchpad on laptop
You should have a little icon in the right corner of your taskbar, right click on the touchpad icon and click enable.
If that does not work, right click on my computer icon,properties, hardwrae tab, device manager, look down list for mice and pointing devices, click on the + sign, select synaptics(if that's the make) and select uninstal.
Restart laptop and the drivers will automatically re install and should work as normal
Nov 20, 2007 | Acer Aspire 3680 Laptop
Open Questions:
hp presario cq60 connects to network but not to internet hp presario cq60 connects to networkb but not to internet. I replaced the wifi card. I've tried to connect to hot spots and to wireless routers. I can connect to them, but no internet. Says Local Only. I have tried the following... 1- Click Start, then type ncpa.cpl and press Enter 2- The "Network Connections" window will show up 3- Right click Wireless Network Connection and select Properties 4- Click the Networking tab. Click Internet Protocol Version 4 TCP/Ipv4 and then click Properties 5- Select "Obtain an IP address automatically" 6- Make sure also that "Obtain DNS server address automatically" is selected 7- Click OK Then please follow the steps below also: 1- Open Internet Explorer (even if you use another browser) 2- On Internet Explorer click Tools, then click "Internet Options" 3- Click Connections 4- Click "Lan Settings" 5- Make sure "Automatically detect settings" is SELECTED 6- Make sure "Use automatic configuration script" is UNCHECKED 7- Make sure "Use a proxy server......" is UNCHECKED 8- Click OK 9- Click Apply then Click OK I've also tried...1- Click Start, then Control Panel 2- Now click "Network and Internet" 3- Then click "Network and Sharing Center" 4- And then click "Manage network connections" on the left 5- Right click "Wireless Network Connection" and select Properties 6- Click the Networking tab. Click Internet Protocol Version 4 TCP/Ipv4 and then click Properties 7- Select "Use the following DNS server addresses:" and enter the following 8.8.8.8 8.8.4.4 (remove the old ones if you have it) 8- Click OK and wait 60 seconds or so. I've also tried... Please click on Start->All Programs->Accessories, then right-click on Command Prompt and click on Run as administrator. Then type: netsh winsock reset , and press Enter. ipconfig /release , and press Enter. ipconfig /flushdns , and press Enter. netsh int ip reset netshlog.txt , and press Enter. Then restart the computer and check. Nothing has worked. Still allows me to connect to a wireless modem or a hot spot but not to the internet. It displays "Access: Local Only". I've tried other laptops and they allow internet access using the same wireless modem or hot spot. Yet, as I stated before, When I was in the hospital, I could connect to their wi-fi and get internet access. I also can connect this laptop to an ethernet cable and connect to the internet.
Nov 16, 2011 | HP Compaq Presario CQ60-249US Notebook
See all HP Compaq Presario CQ60-249US Notebook Questions
HP Compaq Presario CQ60-249US Notebook Logo
125 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
