Question about Jandy Aqualink Rs4 One Touch Control System Control System
"Check aqua rite" message reset
How do you do a "Check aqua rite" message reset. The work has been done but I can't get the display message to go away.
What is wrong with my Aqua Rite Electronic chlorine Generator.
when unit goes off see if voltage from transformer if not bad transformer if os bad cell and sensor
Sep 09, 2016 | Hayward-Goldline Aqua-Rite Electronic...
Hayward swimpure plus no power light led
if voltage to unit and switch check transformer if voltage check display
Mar 08, 2015 | Hayward-Goldline Aqua-Rite Electronic...
Hayward Aqua system filter will not run
Hi, I believe you have an Aqua Rite Salt Chlorine Generator. Check system with no flow will always happen on start up but once flow is constant it will go away.
Sep 01, 2014 | Pool & Spa
Aqua rite rs4 error messages
if using aqua pure check sensor and cell
Nov 04, 2012 | Jandy Aqualink Rs4 One Touch Control...
Hayward Aqua Rite Not showing salt and temp readings
see if voltage from transformer if ok bad control board or sensor
Jul 09, 2012 | Hayward Pool Products Hayward Aqua Rite...
I have a three year old Aqua Rite Generator. The lights on my panel have stopped working. Only light that works is "NO Flow" when you first turn it on, then it goes out. I have tried pressing...
They make a display board that is replaceable. Part# GLX-PCB-DSP
That should correct the issue.
It is a very straight forward procedure. Please make sure that all breakers are OFF before you begin.
Apr 01, 2011 | Aqua Pool & Spa
How do I reset the EFO Aqua Control system?
Thanks Guest! It worked perfectly lifting the face of your machine by 45 degrees
The washing machine was full of powder (this was the cause)
Aug 16, 2008 | AEG Lavamat 88840 Front Load Washer
Jandy Aqualink Rs4 One Touch Control System Control System Logo
162 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
