Question about Garden
Engine starting problem
My Mountfield ride on has been good for years but this year it needed charging. After charging it was fine twice starting ok but third time when turning key, ignition light came on and all I heard was clicking noise but starter would not engage. I charged battery and tried again but the ignition light does not come on and nothing is heard when turning key to start. I took battery to Mountfield dealer and he charged battery and said he thought battery was ok as it warmed slightly when being charged which he said was good sign and he checked charge at full 12v.When I came home I fitted battery back on tried starter, no ignition light and no response when turning key to start. I crossed solenoid terminal and starter turned but it did not fire at all. Smelt petrol but will not fire. I have pedal down on break, seat down, and blade disengaged. I am puzzled. Any advice please.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
The battery still may be bad. The fact that it "warmed slightly when being charged" doesn't suggest it to be good - instead it could have high internal resistance in one or more cells. A battery with this failure still measures a good 12V until you put a load on it. I'd take the battery to a battery store, not a lawnmower dealer, and have it tested there with an actual battery tester. If it's bad, replace it. If it's good, then it's probably the solenoid and that means you'll have to replace the starter/solenoid assembly.
Posted on Jul 06, 2010
Why is the Alternator not charging the battery?
If you're sure the alternator is ok then there is another issue. I would definitely check all the fuses. I would need the make and year to further assist.
Nov 11, 2015 | 2000 Ford Windstar
Why car wont start after killing the battery twice?
When you run a battery down a few times, over a year or so,
then kill it twice, in a row, in a couple days,it has to be replaced
Oct 29, 2014 | 1999 Pontiac Firebird
Dear Sir, I have an Mountfield m4 major petrol lawn mower some 20 years old. It starts O.K. but the engine will stop after a few minutes.By turning the choke on just before the engine stalls, will keep it...
sounds like the needle valve Seat is slightly clogged and the gas entering the Carburetor cannot keep up with the Draw from the engine.
Oct 05, 2013 | Garden
I have a 2008 Suzuki Boulevard C90. The battery is about 1 year old, I ride most of the year around and put it on a 1 amp battery charger about every two weeks whether need to or not. Went to start this...
I think you need a battery it is not holding a charge Also take voltmeter when you jump it When running put voltmeter on battery and see how many volts is charging while running It shoud be 13,50 GOOD LUCK MOPAR KENNY
May 22, 2011 | Suzuki Boulevard C90 Motorcycles
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
I have a jd 100(?) series riding mower that has
First, charge the battery.(Always do the easier things first). If that isnt the problem, take a DC volt meter and check the voltage where the battery connects to the solenoid. Then check the voltage on the starter side, while you turn the key,If there is a large voltage drop, or no voltage, replace the solenoid. If voltage okay, then check the starter. Good luck...Lee
Aug 22, 2009 | Garden
My Husqvarna LT1538D riding mower only charges the battery up to about 12.3 volts. So, I have to charge the battery, a new one, about twice to get through the cutting season. The dealer worked on it last...
On almost any engine you pull the flywheel and you will see the charging coil. Once out it can be tested by yourself or any competent electrician. Good luck. donnyb60
Mar 27, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
346 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
