Question about Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
I want to connect external speakers to TV in order to watch a DVD with better speakers. I do not know where to plug them in.
  • Sharp Master
  • 11,800 Answers
On your tv you only have a Digital audio output (optical) ( TOSLINK ) which means that you can connect to it only a receiver that has an optical entry and only to it you can connect some speakers.
Posted on Jul 05, 2010
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
Picture is fine but there is no volume however, volume comes on when I play a DVD
If sound when a DVD the set is ok.
Look:
Is sound turned down on set or muted and same for a cable or sat box if used for signal.
In menu are speakers turned off or on?
If set has hookup for external speakers is it switched to internal or external.
A setting in the set or the box used is causing this as the set is not smart enough to know when you are playing a DVD or just watching TV.
triple check all connections from box and in the set.
Apr 22, 2012 | Sylvania LC320SS8 32 in. LCD Television
My television shows clears it just that there is no sound coming out. What is the problem?
  1. Isolate the problem. The main troubles that will crop up with a TV set are either no picture, no sound or both.
  2. Check the input setting on your remote control. If you have other devices connected to the TVCheck the power. Don't be embarrassed if your problem is as simple as an unplugged power cord. It's better that you should discover this than pay a repair technician to come out to your house and find out.
    , such as a video game system, those devices must be used with a different input setting than the input you use for watching programs or movies on a DVD or Blu-Ray player. Chances are, the kids were playing a game and forgot to turn the input back the way it was.
  3. Press the Input button on your remote control to return to the setting you wish to use. For example, the cable box might be connected to Input 1 and your DVD player might be connected to Input 2. Newer television sets have at least 3 inputs.
  4. Check the coaxial connection from your cable or satellite receiver to the television. The cable should be attached securely by twisting the round lock nut clockwise. Also check the power connections for the satellite or cable receiver. If either is unplugged, you won't receive a programming signal on the TV.
  5. Make sure the video cable is securely attached to the TV jack if you have a home theater system. The video cable runs from the Video Out jack on your home theater receiver to the Video In jack on the back of your TV.
  6. Check your receiver setting. Home theater receivers manage several components, so if you have the receiver set to operate the CD player but you are trying to watch a movie on your Blu-Ray player, you'll need to change the selection to Blu-Ray to watch the movie on your TV.
  7. Check the TV speakers to see whether they have been muted by accident. Press the volume button on your remote control or go to the Menu section and scroll down until you reach TV Speakers. Toggle left or right to turn the speakers on or off.
  8. Press the speaker button on your receiver to make sure your external home theater speakers are activated. Many home theater systems use external for their superior audio rather than the speakers inside a television.
  9. please rate or vote me on me and how helpful it was.
Feb 05, 2011 | Disney Fairies 20'' TV & DVD Player 14...
I have a cable TV connection, analogue, no hdmi, how do i connect dvd player and my other speakers to the TV?
You could purchase an "RF Modulator" box (a very small electronic box) which is designed for connecting DVD players to TVs which have only a coax cable input. The 'RF Modulator' box needs to also have the external audio connections ('RCA plugs) for diverting the audio signal to your external amplification (other stereo & speakers). These RF Modulators are found at most stores, and run $16 - $25.
Feb 05, 2011 | Philips Televison & Video
Someone gave me this system without a remote. When I turn up the volume, my TV and the system echo each other. What can I do?
It's customary to mute the TV speakers if you're using external, presumably better, speakers. The best TV-related audio would be obtained not from the TV but from the original source you're watching - CD/Cable/DVD/BluRay/Game.
If you have the manual you might also want to see the settings for speaker distance from the listening position as that can cause an indistinct sound image if grossly incorrect.
Dec 09, 2010 | Progressive Computer JSI 6 spkr. Home...
Volume low when watching dvd
Not much you can do about this. The movie industry sets movies to low volume when recording for better sound. They expect you to have the equipment to boost the sound. This cuts down on their outside noise. Only solution for this is to install external speakers as I have done for my movie or TV playing (I installed a TV adapter so I could hook up a projector and display the BIG game outside) but as you say, we couldn't hear it until I hooked up external speakers.
Dec 27, 2008 | Toshiba Satellite A135 Notebook
Sharp XR-1S Projector
you'd be better off hooking the dvd up to an amp and run speakers off of that.
Jul 17, 2008 | Sharp XR-1S Multimedia Projector
No sound from one speaker
techs are correct. sorry.
what type of TV are you using?
if it can be firmware upgraded via USB connection. that might do the trick.
May 15, 2008 | Bose Cinemate Digital Home Theater System...
Home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
Sharp LC-26DV12U 26 in. LCD TV/DVD Combo Logo
415 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
