Question about Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis, MDG7400AWW, dryer, Intellidry
I have a Maytag atlantis, MDG7400AWW, dryer, Intellidry comes on @ less dry position and Perma press cool down position, and Time dry @ all settings. Won't come on other Intelli or Perma press positions. Is my timer going bad?
We have a maytag intellidry atlantis gas dryer model #MDG7600 AWQ the timer knob has come off the dryer how can we get this dryer working?
You should be able to purchase a new knob through the website and it is fairly easy to put back on. Check websites such as http://www.appliancepartspros.com/ in addition to the Maytag website
Dec 18, 2011 | Maytag Washing Machines
My Maytag Atlantis Intellidry Dryer won't start unless I move it around
If you have to move the whole machine then I would say you have a bad wire somewhere. If you have to move the timer around then you have a bad timer.
Dec 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Ihave a maytag atlantis gas dryer model mdg7400aww that when I first start it up it gets warm but then stops heating? what is the problem
The operator coils get hot and quit on these ,when they get a little age on them, quite difficult to diagnose. If the coil feels hot to the touch after failure then that is a clue. f00c98f.jpg
Mar 05, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
What happens when the timer goes out my maytag atlantis dryer
how do I replace the timer knob on my Magtag Atlantis Dryer MDG7400AWW
Jan 10, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Intellidry cycles inoperative, regular timed cycle is fine ,Maytag Atlantis MDE7400AYW, intellidry sensor shows continunity
Howdy: It seems the "smart switch settings" has died. It is in the switching circuit. It all comes in one unit. Take it out and have it tested at an appliance store. Good luck - Doug
Dec 09, 2009 | Maytag Dryers
My Atlantis won't start after I ran it with the lint filter out
might be a sock or something in the blower housing jamming the motor
Sep 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Only heats on timed drying
Our Kenmore dryer had the same sort of problem (different catchy names.
Problem was that in "smart" modes (by what ever name, the timer motor runs in series with a "dampness" sensor (thermostat, actually, I think) and A RESISTOR.
Resistor burns out--this is the symptom set.
Apr 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
121 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
