Question about Philips 20PF5120 20 in. EDTV-Ready LCD Television
My Philips 20pf5120 TV has picture and sound but it continually blinks all the time. How can I fix this?
  • Philips Master
  • 11,800 Answers
I'm assuming that by blinking you mean that the led is blinking - if the screen is blinking then the problem is with the CCFL tubes and since these are very hard to find it will be cheaper and easier just to get a new tv.
The led is blinking in only 2 cases: 1 - when there's a command signal active and 2 - when the power source of the tv autooscillates.
1 - appears when: the remote is constantly sending a signal - easy to test, remove the battery; one of the buttons on the tv is busted and constantly on - the volume or the channel will be constantly changing, you would see that; the IR sensor or the processor from the tv is malfunctioning - you must open the tv and test it.
2 -  an capacitor has aged and no longer does its job of filtering the current - you must open the tv to check and replace the faulty one.
If you don't have even the most basic experience in the tv electronics then it's time to call a repairman.
Posted on Jul 05, 2010
Blinking color on screen no picture
Sounds like a panel fault. Contact the authorized service center for Philips to confirm.
Gopakumar Gopalan Google
Apr 17, 2014 | Philips 42TA648BX 42 in. LCD TV
I can not find user manual free online for philips Tv 20pf5120/28
try this web address
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=US&ctn=20PF5120/28
Dec 27, 2010 | Philips Televison & Video
I own a philips hdtv dlp. yesterday, it seemed as if it might need new bulbs but today it won't even come on. the blue power light (in the front) is continually blinking. what does this mean? a new a tv? i...
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 25, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Model ID 20pf5120/28
Recently, cable has gone digital. You might not be able to get a signal anymore with rabbit ears. They suggest buying a converter box. You can always try restoring factory settings...
Jun 15, 2009 | Televison & Video
Phillips 20 inch flat tv
usually a blinking led points to your power supply! You will probably find some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain). sometimes there is more then 1 thing wrong.
Feb 28, 2009 | Philips 20PF5120 20 in. EDTV-Ready LCD...
Remote codes for dish network remote?
1. Mmanually turn on the device (TV, DVD, etc.)
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quiclkly release the desired mode button 9TV, DVD, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device (TV, DVD, etc.) changes channel. The red indicator blinks once with each button press. If you accidentally overshoot the code required, use the CHANNEL DOWN button to backtrack through the library until the device again changes channel. Pressing the CHANNEL UP changes direction to forward again.
5. Press and release the MUTE button to install the code.
or try these
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917 good luck its one of these!
Oct 25, 2008 | Philips 20PF5120 20 in. EDTV-Ready LCD...
20pf5120
Are you connecting the tv to your source using the DVI, component (Red Green Blue + 2), or composite (Red, Yellow, White)?
Try switching the type of connection you are using. If you are connected via component, then switch to composite. If the problem persists even on composite connectors, then the issue lies with the TV. If the composite cable works fine, then the problem is most likely the cable you are using.
Press the sleep button, and make sure the sleep timer is set to OFF.
Unplugging the TV from the wall outlet resets the TV.
If you have a cable or satellite box connected to the TV, then try resetting the box also by turning off/unplugging from wall outlet.
Surge protectors can cause some occasional anomalies with LCD TV's (they're still a good idea) - just reset the TV to clear up these anomalies.
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Actually Philips 20PF5320/01 Fault no power, blinking LED
ok you have defective power supply! from the secondary power supply! or hot side.
Oct 08, 2007 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Philips 20PF5120 20 in. EDTV-Ready LCD Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
