Question about Amana NDE6800AYW Electric Dryer
My Amana heavy duty dryer will not get hot - Amana NDE6800AYW Electric Dryer
  • Amana Master
  • 43,501 Answers
Hi, If you have a gas dryerMy Amana heavy duty dryer will not get hot - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a My Amana heavy duty dryer will not get hot - 2_bing.gifdifferent problems...
Check out this tip that I wrote about this problem...
Troubleshooting2_bing.gMy Amana heavy duty dryer will not get hot - 2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
3 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: Amana Heavy Duty Dryer turns on and gets hot but wont turn inside
Hi, To get to the belt, remove the screws on both sides of the door opening. The dor will lift off. Pull on the front panel and set it off to the side. You will need to remove the front panel holding the drum up. It is not a hrad job but, another set of hands to help makes a difference.
I have a pic of you dryer but it doesn't show a good view of the back. Some models have an access panel to make it easier to finish putting the belt on the idler pulley and motor pulley.
It is tricky when you have to put the belt on reaching in from the front.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 10, 2009
  • 122 Answers
SOURCE: I have the heavy duty 4 cycle Amana dryer. When I
sounds like motor bearings are failing. causes motor to overheat and cut out on motor protector. I'm afraid a new motor is in order.
Posted on Jun 15, 2010
AMANA HEAVY DUTY DRYER model #NDG2335AWW
m ost likely one of the rear drum support rollers is bad. the part number is 37001042.
Mar 21, 2012 | Amana NDG7800AW Gas Dryer
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
My Amana Heavy Duty Dryer will not heat up. It tumbles but it doesnt warm up. WE have cleaned out the the machine and the vent to the outside.
You didn't state if it is a gas or electric dryer. If gas the igniter element is bad, if electric the heating coils need replaced. Goodluck Google burdfrenzy
Nov 26, 2010 | Amana Dryers
Belt worn out - need to find the model number: amana heavy duty gas dryer - limited edition
you gave the model number it's NDE6800AYW,the belt part number is 33002535 and it's around 25 bucks
Jul 31, 2010 | Amana NDE6800AYW Electric Dryer
I have the heavy duty 4 cycle Amana dryer. When I turn it on it is very loud and stops after about 20 minutes. It smells really hot so maybe it's overheating? But why?
Jun 15, 2010 | Amana DLE330RAW Electric Dryer
I have a gas Amana Heavy duty dryer LG5309w it starts and after 5 minutes it shuts off...any suggestions?
If the dryer has a sensor dry function, look inside the drum and locate the moisture detector. It'll probably look like two metals bare. Clean it real good with rubbing alcohol. If that doesn't fix your problem you'll need to work on the dryer.
Oct 16, 2009 | Amana DLE330RAW Electric Dryer
Amana dryer
If you have voltage across the heating element and it does not heat, replace the element. If you have no voltage, trace it back to the thermostat and control board.
Oct 02, 2017 | Dryers
Amana heavy duty clothes dryer, model LE8407W2 screeching loudly when running for first several minutes....then stops.
Belt idler pulley sounds dry, oil all rollers and belt pulley.Please leave a Rating! Thanx!
Jun 05, 2008 | Amana Dryers
Amana NDE6800AYW Electric Dryer Logo
539 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
