Question about Electrograph Systems DTS42PT 42 in. HDTV-Ready Plasma Television
How can I obtain a User Manual for this plasma TV Electrograph Systems DTS42PT?
SOURCE: Electrograph DTS4225PTD Plasma TV 42"
It's Y upper buffer, also cross matches, with LJ41-02760A which is for Samsung 42 Plasma
Posted on May 02, 2008
SOURCE: User Guide for Proscan TV
http://www.oncorpus.com/down/ENG/42LA45H%20English%20UM.pdf
Posted on Sep 18, 2008
  • 3 Answers
SOURCE: Zenith Plasma TV Manual
I found it posted here MFL34797058_0.pdf
This is the web site...
http://tv.manualsonline.com/ex/thread/view/idThread/329713
Posted on Jun 03, 2009
omaharox
  • 165 Answers
SOURCE: need user manual in english,lg plasma tv 50pq60
Go to www.lgusa.com and you can download an english owners manual.
Posted on Jan 09, 2010
SuperTech-11
  • 1591 Answers
SOURCE: Have a 55 inch plasma
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 07, 2011
Power supply
Check and replace its main board. It is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 01, 2014 | Electrograph Systems DTS4225PTD 42 in....
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
Bought display w/ no remote, and am hoping to use my Logitech Harmony 880. Any idea how to get it working? The logitech software recognizes the DTS4230 model, but the TV does not respond to the remote.
Hi. If you do not have the original remote for the device, you can call Logitech support. They have the ability to copy in commands for you that other customers with the same model TV as you have learned.
Hope that helps :)
Dec 15, 2009 | Electrograph Systems DTS4230 42 in. Plasma...
Hi, I have a DTS42W Electrograph that turns on but no image coming on but i can see the on screen menu perfectly, help please!!!
check the cables going to your unit, if the graphics are ok the tv is ok, hast to be a bad connection.
Dec 10, 2009 | Electrograph Systems DTS42W 42 in....
Dts42w will not turn on ? i see a red light in back of set on
what kine of additional plug i need to plug in i am having problem learn how to trouble shooting the power in the tv also i am having problem with the tv tube i am trying to learn how to do these thing so that can help myself and my letter son i have no money ta this time is there anyway that you all can help me thank you
Dec 18, 2008 | Electrograph Systems DTS42W 42 in....
Feb 29, 2008 | Electrograph Systems DTS4225PTD 42 in....
Electrograph Plasma TV
you could buy an all for one remote control. i bought the kameleon 6 for 1 and its very easy to programme. just put in one of the codes supplied in the book for the brand of tv you have, once youve put in right code there should be no problem setting up the tv. The best place ive seen for the kameleon remotes is ebay, very cheap compared to what i payed. hope this helps
Feb 09, 2008 | Electrograph Systems DTS42PT 42 in....
No picture
my brother get your tv checked by a tech the tv is having problem in the IF circuit.good luck.
Apr 16, 2007 | Electrograph Systems DTS42PT 42 in....
DTS34-CRT - what universal remote setting for "TV" is compatible?
try these guys, i have had no luck online; http://www.electrograph.com/default.aspx?id=008&hid=77650348034E1B8CE3EF49687496D4C4 if you let us have the remote model number we may be able find out from that side. Hope this helps :)
Mar 17, 2007 | Electrograph Systems Electrograph...
Electrograph Systems DTS42PT 42 in. HDTV-Ready Plasma Television Logo
Top Electrograph Systems Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Henry  Thomas
Henry Thomas
Are you an Electrograph Systems Televison and Video Expert? Answer questions, earn points and help others
