Question about Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer
I destroyed the standard connection for the printer to the cpu. The small one nearly square. Is there another connection on the back of the HP6480 that I can use like usb connection below the small square one?
    President:
  • 2,678 Answers
No there isn't
Posted on Jul 05, 2010
How do you correct error code 2833 on a konica minolta bizhub 6500
Remove the Cyan Drum, once done you will see a small chrome/silver bar near the front of where the drum will be the small silver strip has small tiny little square on it inside that square is a sensor, use a small clean brush and clean it, recommend you might do all four of them. That sensor monitors the drum for certain voltage settings,
Jun 25, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub pro c500 sc code 29-21
Remove the cyan drum and clean the very small sensor with a brush or can air. The senor is a tiny square on near the front section of the drum and behind when you remove the drum you will see it. If that does not (DO NOT USE A VACCUM CLEANER) The static electricity fro the vacuum cleaner will destroy it.) need to replace the drum or the sensor worse case to image control board that the sensor talks to. (swap a drum see if the changes it)
Oct 17, 2013 | Minolta Office Equipment & Supplies
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
I need the cable that goes from my printer to my pc
Its a standard "printer usb cable" that can be gotten at any computer store, radio shack, best buy , walmart, etc
Dec 18, 2009 | HP APOLLO P-2150U InkJet Printer
Beeps but wont boot
some hard ware problem i think..try to replace RAM ...
Dec 03, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Ican't install my printer hp6480 to my computer
What happens when you try to install?
Have you tried downlaoding the drvier from HP.COM?
May 02, 2008 | Office Equipment & Supplies
During boot and in Windows video displays columns of small squares.
You eed to return back your VGA card cause it's damaged.
Hope this Helps.
Apr 30, 2008 | Computers & Internet
Siemens A55 software fault?
This is most likely a cracked solder joint on the baseband CPU - you basically need to take the PCB out, remove the screening covers and the keyboard/display and reheat the CPU with hot air - it needs to get hot enough to reflow the solder on the under side, but not so hot you destroy components - about 280c is good, and use foil to screen the other parts so as not to cook them.
The CPU is the big square chip in the top of this photo (this is from the back of the board with the cover and the screening cans removed).
Mar 04, 2008 | Lands Phones
Please help
The first time I installed a new motherboard I did not realize there were two power cables, one has a small square connector and the other a long rectangular connector. Did you connect both power cables?
Nov 27, 2007 | Gigabyte GA-8S661FXM-RZ Motherboard
Dead Mobo?
Do you have both power connectors from the PSU hooked up?
You need both the large one near the ram, and the smaller square 4-pin one near the printer port
Nov 22, 2007 | FIC K8-800T Motherboard
Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer Logo
Top Digital Products Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alan Rothery
Alun Cox
Are you a Digital Products Office Equipment and Supply Expert? Answer questions, earn points and help others
