Question about Frigidaire GLGT1031C Dryer
Frigidaire GLGT1031CS1 washer timer
I have a Frigidaire GLGT1031CS1 stacked washer/dryer unit that is about 5 years old. The dryer still works like new, but the washer suddenly stopped switching cycles, as if the timer is bad. It will fill with water and begin agitating, but the knob never moves and so it never rinses or drains. Is this something I can fix?
  • 619 Answers
Yes. Replace the timer and you are good to go.
Posted on Jul 06, 2010
How to diagnose washer timer not turning?
Good Afternoon Friend,
I understand that the washer timer on your Frigidaire laundry center, model# GLEH1642DS, stopped turning and you want to know how you can diagnose this. Typically, this is not be a do it yourself repair, as there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose it and determine what is causing the timer button to not turn. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
My Frigidaire FEX831CS Top Load Stacked Washer / Dryer goes through the cycle till it gedts to drain, then nothing... pump out?
Hello trinileigh19 - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 24, 2012 | Frigidaire FEX831CS Top Load Stacked...
I have a stacked washer and dryer and the washer will only start when the dryer is on
Contact a professional. You have a power concern with the unit that will require the main control boards and timer to be checked by a technician.
Aug 11, 2012 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
The timer don't move.
If you are certain the unit has power, then replace the timer. It is common for the timer motors to fail on these units
Nov 23, 2009 | Frigidaire FLGB8200DS Top Load Stacked...
Dryer will not heating up. Only 5 years old
Two possible reasons:
1. The heating element or the temperature sensor is broken.
2. The exhaust vent is obstructed and needs to be cleaned.
Good luck.
Oct 01, 2009 | Frigidaire GLET1041A Top Load Stacked...
Frigidaire GLGT1031C Dryer Logo
276 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
