Question about Acer Aspire 3680 Laptop
Acer Aspire 3680 2682 will not power up
Can you help
  • 13 more comments
  • jamest1961 Apr 19, 2008
    Have 2 identical,have swapped batteries and ac adaptors,no power.How do you troubleshoot th motherboard before buying and swapping it out?
  • Pieunome Apr 20, 2008
    Yes thanks. The battery seems to not be charge enough to crank the comp up. The charge plugged in will also not start the computer. I need a fully charged battery first before I can start to blame the mother board.
  • Anonymous Aug 01, 2008
    my computer powers on with ad adapter and with the battery however it is on only for about 3 minutes, I can see that the power light is blinking and them the computer goes off. when i press the power button again the computer will not turn on even thought every time i press the power button the green light on the front is on for about 2 seconds, if I wait for at least two hours since i the computer worked for 3 minutes then in turns on again for about 3 minutes and the whose circle begins again. I have taken off everything that can be cousin the problem but nothing seems to work I even change the head sink and fan still no luck. I am guessing it is the power board or the motherboard itself. Please let me know if yu had the same problem how did you solve it?.
  • rickeyricca Aug 10, 2008
    will not power on
  • Anonymous Aug 18, 2008
    my laptop aspire 3680 when plugged in using ac adapter won't start. LED's were not blinking even with the battery. i think the board is dead.
    When i plug in the ac adapter, i noticed the LED of the adapter is blinking and seems that there might be a shorted circuits inside.
    any help? ideas? thanks. email me at: waquita@tollways.net.ph
    My laptop is plugged on I could find the LEDs displaying green but my screen is not illuminated.I could find the OS working fine as the XP screen could be identified at teh background evn though the screen is not illuminated.I have tried adjusting the brightness contrast but still no use.
    Could you pls help??
  • bal0T Oct 06, 2008
    my acer aspire 3680, has this problem..
    it wont start, no led lights turn on, I have tried to remove the battery and connect the power adaptor to the power jack, no lights turn on.
    and i tried to remove the battery, and put the plug out.. still lights on.
    then when i reconnected the battery, w/o plugging in the adaptor, my note book turned on.. i tried to off it and turn it on, when happens it wouldn't work again..
    what seemed to be the problem??
    could i get any guide to dismantle my note book so i can trouble shoot it??
    i really what to fix it, but i'm not that good in notebooks rather than desktops.
    thanks..
    need a real help
  • Anonymous Mar 06, 2009
    i cannot turn on my acer aspire 3680.i don't know which part of my laptop has a problem. when i plug it with its adapter,the battery indicator turns orange...but it never turns into green.is this means that the battery has a problem?
  • kaybryant Mar 12, 2009
    I have an aspire 3680, it won't turn on with just the AC Cord, it acts like there isn't any power at all. When I plug in the battery with it the green light in the front is on but still will not power on. When I leave the battery in and unplug the ac adapter the green light goes out.
  • Anonymous Mar 14, 2009
    I hava a Aspire 3680 that shuts off after 6-10 minutes of operation
  • spectrumthre Apr 26, 2009
    Vista start up screen appears, then screen goes black, lcd lights are on, don't have any start-up or repair discs. Any ideas?
  • edemerson59 Apr 30, 2009
    The Acer Aspire 3680 when powering up does not show anything on the screen, Battery light is green and power light is yellow, please help
  • Anonymous May 01, 2009
    DOES ANYBODY KNOW HOW TO OPEN THE ACER ASPIIRE 3680? BECAUSE I THINK MY ADAPTER PLUG IS BROKEN INSIDE.
  • heysharma
    heysharma Jan 21, 2013
    cannot undersyand whats being told here! Oooouch!!!
  • heysharma
    sorry friend. unclear! what is being told by you is unclear. Oouch!!
    Sergeant:
    Champion:
  • 244 Answers
There are some reasons laptop can't power on, try to troubleshoot.
1. Make sure that your ac adapter is working. if you plug battery and ac adapter, the battery chargin led will be orange and if the battery is full, the led will be yellow.
2. Can you power on using battery ? if you can and you can't power on using ac adapter (i assume your ac adapter is working). the problem will be your power port.
if you can't power on using battery and your battery is working ok. the problem will be motherboard.
Posted on Apr 18, 2008
  • superbbq Apr 20, 2008
    for jamest1961.
    To troubleshoot your problem:
    i assume you have 2 laptop, 1 is working laptop and 1 is problem laptop (no power).
    for Aspire 3680, the power port isnot in the motherboard, it's on the separate board.
    To troubleshoot the motherboard, attached the live battery with trouble laptop. if your laptop can power on, it's mean your motherboard is ok. the posibility is either your ac adapter or the power board is bad.
    next step is plug good ac adapter to the problem laptop, if you can't power on it's mean your power board is bad.
    Problem Solver:
  • 13 Answers
These computers have power ports that are easily broken when you connect to a power source. twist the power/cable connecting to the computer untill it comes up with "charging", and leave it. To turn it on, keep disconecting a connecting the power, and twist untill somthing picks up, as soon as its booted, make sure you alter it to charge, then leave.
OR another solution...Another laptop might be the way to go, these laptops are sluggish as hell...mines running vista, 512mb or ram.. how does it even leave the factory with half the needs only of the operating system implemented? vista needs at least a gig...even then its shocking, my advice, stick with xp, much more better, the sooner vista comes of the shelf, the better.
Posted on May 01, 2009
    Problem Solver:
  • 30 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
5sd4
Posted on Jul 20, 2010
I have a acer laptop aspire 5680 and the timeclock is not working.is this a problem of the Motherboardbattery?
Posted on Sep 13, 2008
Hi
hjjkkl';';
Posted on Aug 18, 2008
5 Suggested Answers
  • 244 Answers
SOURCE: All Drivers for Acer Aspire 3680
you can download from www.acerpanam.com
Posted on Oct 01, 2008
crashmech
  • 67 Answers
here are all the drivers for this model
click here
any more problems email me.
Posted on Sep 27, 2008
  • 121 Answers
SOURCE: Replacement Hard Drive
you would need a 2.5" sata hard drive. whatever size you prefer.
Posted on Apr 24, 2009
  • 49 Answers
SOURCE: acer aspire 3680-2682 powers on but black screen
you can referen the article:
How to Fix a Black Screen at Startup
maybe it can give your some help
Posted on Mar 05, 2010
Does this computer have a dc power jack plug or cable
Acer Aspire One D250 AOD250 has cabled dc jack, do not need to solder, plug in and your laptop will work, view this page for reference: http://www.lapdiy.com/acer-aspire-one-d250-aod250-wire-harness-power-jack-dc-in-cable-p-26502.html
hope this can help you!
Dec 27, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
Acer Aspire 3690 my acer powers on but the screen doesnt turn on then it shuts down.
Return to Acer or an authorized acer service center.
Or try replacng the battery and/or power cords first and see if it helps.
Dec 24, 2009 | Acer Aspire 3690-2196 Notebook
Please HELP!! I have a Acer Aspire Laptop
Hello, so does the computer turn on without ac power, if it does it is a good indication that you may have a problem with the power supply or power connector in the computer.
Sep 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
My acer aspire 5720-4126 won't stay powered up
That means that your power adapter is faulty and needs to be replaced.
Hope this helps.
Aug 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
Divers problem
Here bluetooth:Bluetooth Broadcom
Acer Aspire 493X Windows XP Driver
(Download)
You need Winrar to extract it
Here all drivers, they should work as well on 4930:
Acer Aspire 4935 4935G Windows XP Drivers :
Chipset Intel
(Download)
Modem Conexant
(Download)
Webcam Suyin Crystal Eye
(Download)
Webcam Bison Crystal Eye
(Download)
WLAN Atheros
(Download)
WLAN Broadcom
(Download)
WLAN Intel
(Download)
MIR ENE
(Download)
LAN Atheros AR8121/AR8113/AR8114 Gigabit/Fast Ethernet Controller
(Download)
Launch Manager
(Download)
Card Reader
(Download)
VGA Intel
(Download)
Audio Realtek
(Download)
Bluetooth Broadcom
(Download)
Touchpad ALPS & Synaptics
(Download)
VGA NVIDIA
(Download)
from Windows XP & Vista Driver
Mar 02, 2009 | Acer Aspire 4930-6862 Laptop
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5570z
usally bad motherbord u can try using anther power pack but i dought will help seell it on ebay for parts
Jan 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3680 Laptop Logo
3,638 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
