Question about Amana ASD2622HR Side by Side Refrigerator
Freezer cold, fridge not
Freezer at aprox 18 deg, fridge at 60 deg- is the evap possibly not defrosting properly? how do I get to the evap and defrost heater?
  • 1073 Answers
SOURCE: evaporator fan blade jams in ice buildup
check the defrost bimatal or defrost thermanstat it will be located on the evaperator suction line (large line) it should read continuity with the ref cold if it showes continuity then the defrost timer is the problem
Posted on Apr 13, 2008
freetek
  • 5568 Answers
SOURCE: GE built in Fridge does not defrost and freezer ices up
Defrosters are commonly controlled by a primitive timer and this may have a 'dry' and a 'wet' (humid) climate setting that will cause the defroster to cycle generally every 12 or 24 hours.
If set wrong (by accident or on purpose), it can allow too much frost to accumulate before attempting to defrost.
This can cause a gradual buildup of ice.
Also the heating element for the freezer may have failed open so it never heats at all. The connections that need to be checked are often buried between the in- and outside walls.
The timer is probably still OK since you apparently aren't having a problem on the refrigerator side.
Posted on Jun 10, 2008
  • 1122 Answers
SOURCE: Troubleshooting defrost system failure on Amana Fridge
YES YOU GOT IT,IT'S THE BOARD BECAUSE EVERYTHING ELSE CHECKED OUT GOOD,BOTH FANS,HEATING ELEMENT,DEFROST THERMOSTAT,THE ONLY OTHER THING I WOULD DO IS TURN THE THERMOSTAT OFF IN THE FRIG.TO SEE IF THE COMPRESSOR AND FANS TURN OFF,WAIT 3 MINUTES AND TURN IT BACK ON, IF THAT CHECKS OUT THEN IT HAS TO BE THE DEFROST TIMER,LET ME KNOW-MIKE
Posted on Jul 02, 2008
  • 958 Answers
SOURCE: Defrost Heater Resistance Range
21.3 ohms is just fine for a defrost heater. this heater is low wattage since it is an adaptive defrost. you could have problem with temperature sensor since you have replaced the board already.
tnx for using fixya,
drcool
Posted on Sep 30, 2008
  • 61 Answers
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Posted on Oct 20, 2008
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Why is my upright fridge freezer bleeping constantly, both fridge and freezer cooling ok
Model number? Usually that is warning that something is wrong. Example defrost not working properly thermistors are defective, or door open. Need your model number to give you answers
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
My ge profile pfs22sbsss model french door freezer drawer was left open overnight and now won't get cold. Any ideas?
THE FREEZER HAS FROZEN PAST THE POINT OF DEFROST;TURN FRIDGE OFF AND MANUALLY DEFROST ALL THE ICE IN THE FREEZER SECTION AND ALL AIRWAYS TO FRIDGE SECTION.
May 10, 2014 | Refrigerators
Srl629ev refrigerator
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge.Otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | Refrigerators
The fridge portion is not staying cold. The freezer is working fine.
The air damper(that allows air to go to the freezer to frig side) is possibly plugged with frost. or if frost on back panel is visible then the unit is not defrosting properly, three possible failues or combnations 1.defrst heater 2.defrost timer 3.bi-metal defrost thermostat. find which is failed but the fi frost is on the back panel the the quickest tempory fix is this remove all items from the freezer and thaw/defrost the evap coil then reassemble the freezer compartment
Jan 01, 2010 | Frigidaire Refrigerators
Freezer works fine but fridge has lost its temperature.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 02, 2009 | Refrigerators
Fridg not cold. freezer works, defrosted coils, what next: do I replace controller or compressor?
Your refrigerator does not have a simple defrost timer, it has a expensive defrost board. The replacement part number 8201659 it may be found possibly by a group of different company's. At this point I have only found Sears parts direct. http://www.searspartsdirect.com/partsdirect/index.action?pop=flush You can go to this site and put part numbert 8201659 in parts search and play less. http://servicepartstec.blogspot.com/ The offer free answers and help. Thanks, Sea Breeze
Apr 26, 2009 | Refrigerators
Freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Amana ASD2622HR Side by Side Refrigerator Logo
20 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
