Question about Faema FA60081
Bolier not working?
I have a Faema E92 and it will not heat up. It is brand new, so is this a programming issue or is the boiler a lemon? Please help as I can't find my manuel.
    President:
  • 1,618 Answers
Remove the top panel or front panel. Make sure there is water in the machine, and it is in the 0 position. Press the red reset switch, the turn the machine to 1, wait until boiler fills then turn to 2. If after machine fills at position 1 and you turn it to 2 and 1m minutes later there is no heat then your elements could be damaged.
Posted on Jul 07, 2010
We have a Faema E92 Elite, 3 head. The display keeps giving an error code: Boiler overpressure E1. Already replaced the heating element (the gasket as well). How do we get rid off the error message?
You have one of two things going on here, the boiler is really over a safe pressure (very dangerous condition if error is for real) or the pressure sensor is malfunctioning. For safety sake I would have a professional look into this, a boiler explosion is a very dangerous.
Nov 29, 2016 | Washing Machines
Faema E92 error codes E51 and 58 What to check?
Google this question and then post your answer as a comment to update others as well.
Nov 23, 2014 | Faema Coffee Makers & Espresso Machines
Faema e92
There is an economizer valve on the machine that needs to be adjusted. I will assume it was pumping hot water, this is not a new installed machine, then the machine has scale buildup that is preventing the hot water from leaving the boiler through the tubes to the solenoid, only the mixed cold water is being dispensed. If this is a new installed machine, adjust the economizer on the boiler, remove the left panel for access. Big nut on the boiler you will see where it connects to the solenoid.
Dec 16, 2013 | Faema Coffee Makers & Espresso Machines
Sir, LA CIMBALI 39 DOASTAROM 3 GROUP MACHINE MOTHER BOARD BROKEN Sir, We try to install the new mother board, most of the things are working, the boiler is heating up, but when we turned on the...
hi. Im not sure excactly what is going on with your explaination about your machine, but I gather the the original mother board has died, and you have replaced it with a new one. It sounds like you have a water fill issue with your machine. If the boiler doesn't have enough water in it, then the pc board will shut the machine down. Ive never worked on a m39, but they are from the Faema corporation, and Faema/ La Cimbali electronics canbe very complicated. Dont now why they make such complicated electrics, cause there are hundreds of other brands with simple electrics.
If your boiler was empty, then the water fill cycle might be a timed cycle, and is shuting down before the water level has reached the water level probe inside the boiler. If this is the case, then once it has stopped, turn the machine off, wait 10sec, then turn it back on again and let it start the fill cycle over. You may have to repeat this a number of times until it has reached the water level probe inside the boiler. Some machines are designed to have a slow water fill, because when you draw hot water from the boiler for making tea, fresh cold water is pumped back into the boiler to replace what you have taken out, and if it fills too quick, then your steam pressure drops. So by filling slower, the machine will maintain its steam pressure. Good idea in theroy, but its only good for cafes that do 300 coffees per hour.
Im hoping that your machine is configered this way, cause it will probably just have to be turned on a few times until it has reached the water level probe as I explined in the begining. If you have a sight glass, you can check to see how high your water level is. If your level is correct, and its still not working right, then id recomend calling a repairer. There are number of things that could be wrong, causing your board to die. Faulty solenoids. switches, touch pads, pressure switches can cause main board issues. Hope all this helps with getting your machine working properly. Dazza Repairer
Oct 23, 2011 | Espresso RMI La Cimbali Espresso Machine
We have a faema e92 but our mains water is off, can we manually fill the tank without mains water?
The machine can sack the water directly from a water tank since the water inlet hose is conected first to presure pump. Just insert the water inlet hose in a water tank, however please take care that if you leave the pump work without ay water for more than 2 minutes the pump might be destroed.
Feb 13, 2010 | Faema FA60081
Hot Water But No Heat In The Radiators
bleed radiators and check for dirty flame sensor and clean it with steel wool
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Boiler problem
check the air flow,venturi in fan and pressure switch
May 16, 2009 | Sun Time NCAA Purdue Boilermakers...
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Coffee Makers & Espresso Machines Logo
367 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
