Question about Toshiba Tecra 8100 Notebook
Tecra 8100 i was working, but the battery charge got empty, and the laptop shut down, i conect the power cordon, and the lap doesnt star.
    Genius:
  • 3,587 Answers
Remove the battery, run it on ac power pack, for five min, then install battery while it's on.
Posted on Apr 30, 2008
The Toshiba Tecra A8 S8413 laptop cmos battery (or capacitor?) does not seem to be working. Symptoms: I set the date and time. As long as the laptop does not sleep or go into power save mode the clock...
The RTC (Real Time Clock) battery charges when the computer in on (operating). You can plug the electrical cord in and let the computer run for 24 hours by temporarily suspending any sleep mode or automatic power saving features. This should sufficiently charge the RTC battery.
Nov 30, 2009 | Toshiba Tecra A8-S8513 Notebook
Meu Tecra 8100 simplesmente nao liga , funcionava , inseri um hd externo , e desliguei pelo memu iniciar , antes eu so desligava pelo power botton.
Há alguns arquivos que faltam às suas necessidades Tecra 8100 para executar, ele trava no botão de menu porque ele está procurando por arquivos de menu e software que está no seu arranque do programa.
Por favor, desligue o 8100, ligar o HD externo e reiniciar novamente.
Ela vai funcionar bem
Nov 02, 2009 | Toshiba Tecra 8100 Notebook
My Tecra Toshiba will not turn on or off, even plugged in.
Yes it is. And, it is highly recommended that you remove the battery if you're going to use your laptop for more than 1 hour. If you keep your battery in and have the laptop connected to the adapter, the poor battery is going to be charging/discharging so much that its life is greatly shortened. Also, this is what causes dead cells in batteries.
You might possibly have an internal power supply problem.
But, go ahead - remove the battery. See if it helps.
You also might try letting the battery charge for 3 hours with the laptop off.
Oct 12, 2009 | Toshiba Tecra A1 Notebook
Toshiba satellite lap shut down. charged and now will not turn on
Try on AC if works replace battery!!swampratt200!!AAAEEE!!!!
Jul 21, 2009 | Toshiba Satellite A60-S1561 Notebook
Tecra 8100
The battery is rechargeable, you should have received an AC adapter when you purchased the laptop.
Please rate, Thanks!
Feb 27, 2009 | Toshiba Tecra 8100 Notebook
My laptop sudenly shuts down without warning
Sounds like thermal problem.Debris in the fan or heatsink
Feb 20, 2009 | Toshiba Tecra 8100 Notebook
Power on
what about power adapeter is it working fine....
Sep 05, 2008 | Toshiba Tecra 8100 Notebook
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Toshiba Tecra 8100 PIII laptop not booting
It could be a hard ware isuse. Try this.
If you have extra memory or removable Ram ( usually located on the bottom under a panel) Try removing it and starting it, with the ram removed. Then try putting it back in and starting it. If it works, it may be bad memory or it just needed to be reseated. Do this also with the cd drive and wireless card if it is removeable.
also try this with the battery, plug it in and remove the battery and see if it starts.
alot of laptops, like computers will not boot if there is a hardware issue.
The Beeping is a code. The number of beeps and how it beeps usually indicates an issue.
you could look the beep codes up on the toshiba website is the support center.
Good luck.
Apr 15, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Tecra 8100 turns on shows toshiba enter f2
hmmm..that means that your bios needs some attention...it's not too hard to look into that, and see that your disks and other stuff are aligned. You been in the Bios before?
Mar 10, 2008 | Toshiba Tecra 8100 Notebook
Toshiba Tecra 8100 Notebook Logo
99 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
