Question about Watches
I have a 1976 hamilton mantel clock. It has a + and- on the back to set the time. i need to advance the time but am not sure where the adjustments are. Can u help me out.
    Genius:
  • 1,970 Answers
Mcdevito75 here, There nshould be some sort of lever or knob, very close to that a+ and minus- Best bet visit a small watch repair shop in your area, try to draw a sketch of the back of the clock, meanwhlie look on the clock for this lever, it may look like a half moon slot with a lever just in side this half moon slot. Hope this helps.
Posted on Jul 05, 2010
Bulova mantel clock won't keep time
Sounds like a broken escapement, definitely a job for a horrologist (watchmaker)
Sep 29, 2013 | Watches
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
The clock runs fast , 20 plus minutes a day... Is there an adjustment and or how do I deal with this problem? Mantel 8 day clock. Thanks Ron
mcdevito75 here, There should be a F/S on the back of the clock, if so place it in the middle, if not, check out a small watcg repair shop in your area.
Jun 26, 2010 | Bulova Hyannis Desk Clock With Engraving...
Need manuel fo operation and set up
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch/CLOCK manuals.Rate me, please
Mar 15, 2010 | Seiko Mantel Clock With automatic world...
The pendulum stopped swinging...the clock and chimes work well
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
I have a Bulova Mantel clock that is chimming off the hour how do I reset it?
I have a B1987 bulova baradwell mantel clock that is chiming off I can't find my instructions book. please help me to fix this problem thanks
Aug 02, 2009 | Bulova Watches
I purchased an old Hamilton mantel clock that did not run. I have cleaned and oiled it and now it works well except it losses five minutes per day. This has a German movement, spring escapement type,...
This clock has a floating balance escapement.
Hold the balance snuggly with 2 figures. Take a small screw driver and push one of the 4 legs above and attached to the disk to the "+" direction. Move it about 1/4 turn. Set the correct time and check again the next day. If the clock is still slow, move it again and set the hands. Do this until the clock is accurate.
Disclaimer: If this movement was made in the 1970 or early 1980's (The date is a 2 digit # above the movement model number). Those years the clock manufac. (Hermle) did not do well in quality materials. The may need an overhaul or movement replacement. I can provide more information if needed.
Apr 01, 2009 | Watches
Sharp Atomic Clock
I have a sharp atomic clock that once set for the exact time, after a day loses 3 hours.
Sep 02, 2008 | Watches
Watches Logo
215 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
