Question about Mitsubishi WS-55805 55" Rear Projection Television
Sound but no picture
My 55805 has sound but no picture when it is turned on. I took off the front cover and looked for coolant leakage under the tubes per a suggestion to someone else's issue. I did not see any signs. Any suggestions? Thank you.
  • 59 Answers
Hello..the first thing I would troubleshoot is the lamp, check if it is burnt out or just not seated to the ballast correctly. It could also be your ballast is going bad too, may need to replace it. Or it could be your color wheel is going bad if it is not spinning. But if your color wheel is not spinning it could also be your DMD board (digital mirror display) has gone bad also. Wish I could be more specific but this could be one of many different things going bad.
Posted on Apr 18, 2008
Television has sound but no picture.
The liquid is actually CRT coolant dripping down onto the circuits. It will need to be cleaned with denatured alcohol and then dried good. Then any components in the area where the liquid was will need to be resoldered as the coolant will destroy the solder and the circuit traces if left too long as its highly corrosive to solder.
Nov 18, 2011 | Mitsubishi WS-65807 65" Rear Projection...
WS-55805 55" screen that I've had since 2000. Always worked just fine until today! No picture, just sound.
Check Your Rear Projection Light Open Back Cover it a little Door on the back ov your TV Set Possibilty Light Burn Out ....Cause of this Problem Fan Malfunctioning Or The Bulb as to be change for new one ... Type The Brand and the Model ov your TV According To your Model it will gave you a list ov different Light Projector Make Shure You dont Touch the bulb with your bare Hand when you put it On Because those light produce very hi Temperature and cant burn out immediatly or explode.
Sep 22, 2010 | Mitsubishi WS-55805 55" Rear Projection...
No picture, no sound, won't turn ON. Lamp light is ON
It sounds like the color wheel is beginning to fail. I would recommend calling a technician to repair this problem. You can call 1-800-samsung to find the closest service center.
Jul 07, 2010 | Samsung HLN467W 46" Rear Projection HDTV
My bigscreen TV Mithsubishi model WS-55805 just
First thing I do on these is to disconnect power cord,pull off the front speaker grill and remove the small door covering the tubes. Get a bright light and look for coolant leaking down from the metal shields that cover the high voltage anode on the picture tubes. There is a chamber on each tube that contains ethylene glycol or antifreeze to keep the tubes from overheating. Sometimes the gaskets get a leak and coolant drips down onto the circuit board. Look very closely at the board to see if there are any drips below the tubes. If this is the case you may consider replacing the set but some can be saved by cleaning the board and sealing the leaks. Have a pro look at the tv if this doesn't help because all you can get online is a guess. Second thing that could cause this is a failure in the vertical or convergence circuit that would entail part replacement at a cost of 200-300. If you find no coolant on the circuit board that means the convergence circuit or the vertical circuit needs to be rebuilt. These sets are known for having bad capacitors on the boards that eventually have to be replaced when a failure occurs. Good luck, Russmann.
Apr 28, 2010 | Mitsubishi WS-55805 55" Rear Projection...
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
Suddenly, Sound But No Picture
that is not and easy problem U need experienced tech to take a look at your TV call a local TV shop
Apr 17, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Screen goes black
If you are willing, remove the speaker grill and the rectangular board behind that and look very, very carefully underneath each of the three picture tubes for evidence of coolant drops on the printed circuit boards. These sets have been known to spill a few drops of coolant onto the boards and this causes intermittent problems such as yours. This is my first direction in your case. Let me know.
Apr 16, 2008 | Mitsubishi WS-55805 55" Rear Projection...
No sound or picture
OK WHEN A BORD GETS SHORTED OUT LIKE THIS IT MOST LIKLY CAUSES PROBLEMS WITH OTHER BORD'S AND COMPONETS BECAUSE I WOULD GUESS THAT IT SENT A SERG THROUGH MOST OF THE SYSTEM I HATE TO SAY IT BUT I THINK ITS REDY FOR THE TRASH UNLESS YOU WANT TO SPEND THE $ ON THE PROS
Mar 24, 2008 | Akai PT4298HD Rear Projection Television
First looked concave Now its dead
call a tech to repair you tv it is having problem in the power supply or related circuit.good luck.
Apr 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
