Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
If the Clothes deflector brakes can I still use the machine until that part comes in?
  • 478 Answers
Yes, it may not get yours clothes as clean but...
Posted on Jul 05, 2010
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
2001 PT Cruiser,Trac off lite & Brake come on and off. everything checks OK and replaced Computer Module.
'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler. Mods: E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar.
Traded in '02 Silver Touring Edition w/87,000 miles
Jul 26, 2012 | Chrysler PT Cruiser Cars & Trucks
Hotpoint washing machine not spinning with clothes in it
Its either going to be your clutch/brake assembly or the transmission. Both ways are a nightmare to do, and if you've never done one its not something to try for the first time and honestly, being a hotpoint its not cost effective to have a technician come to home and do it
May 11, 2012 | Hotpoint Washing Machines
My GE electric dryer has been making a loud rattling and squeaking noise. Now it is taking a lot longer to dry the clothes. Model # DBSR453EB2WN
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DWSR483EB0CC/0432/0151200/G0205230/00004?blt=06&prst=&shdMod=
As you can see in the diagram the heating element is on the back side of the deflector plate. I would WAG that something got past the deflector and is rattling around between the heater assembly and deflector plate. OR something has come loose and is doing the same thing in that area of the machine. When you have it opened up you should also check the bearing and replace if there is any wooble in it and if not lubricate thoroughly.
Jun 19, 2011 | GE DWSR483EBWW Electric Dryer
I have a eziset 605 it will wash the clothes but when it comes to the spin cycle it wont spin but the agitator still turns causing the clothes to become tangled on one side causing to unbalance. i have...
If you look you will find that when the machine is supposed to spin that is the spin bowl turn. Instead of the spin bowl turning, the agitator is turning and so BALLING the clothes. So......it is most likely a *** designed machine so it has a brake arm and pawl, operated by a small motor or a solenoid. This motor or solenoid is most likely not pulling the brake lever and releasing it to allow spin action. So check the release of the brake. Tony the technician down under....
Apr 02, 2011 | Washing Machines
We have a commerical manitiwoc ice machine that after the bin fills up it cuts off and has to be reset. After resetting it fills up again and a blinking light comes on telling me that something is wrong....
Manitowac uses a plastic deflector which has a magnet located on the bottom. When the machine drops the ice the deflector opens breaking the circuit to the bin switch. This would indicate "Bin Full" condition. As the ice is used the deflector closes and the magnet comes in touch with the bin switch.
Most likely the bin switch needs replacement.
Feb 22, 2011 | Freezers
Fans don't run
Thank you for the complete and literate problem statement.
The red light in question will come on and the media bay fan will spin at high speed if the plastic air deflector door is not in place, OR the white sensor label on the lower right tab of the air deflector door is damaged or out of position, OR the air deflector sensor board is faulty.
You can differentiate a bad sensor label from a bad sensor board by doing the following: Remove the air deflector door. Slide a folded piece of paper through the slot in the enclosure where the right tab of the air deflector would normally be inserted. If the red LED goes out (but stays on with the door in place), the sensor label on the door is missing or damaged.
You will also want to check the sensor board cable connection on the logic board (second from right connector located directly below the hard drives).
Subsequent failure for the fans to run does not necessarily indicate a problem, as the fans are temperature-controlled and will not run until heat rises to a certain level. If the fans are not coming on even when the heat is sufficient, you may need to reset the SMU by shutting down the computer, unplugging the AC cord, waiting 15 seconds, and then replugging and restarting the computer.
May 13, 2010 | Apple PowerMac G5 Dual Mac Desktop
SPIN CYCLE CLOTHES ARE COME OUT WET
there two reasons for this in a TL washer stretched belts or a bad thrust bearing, and lastly check that the brakes are not worn and dragging in the spin, depending on the age of the wsher it may be economically worth investing in a new machine brake jobs or thrust bearing jobs by a tech can be upwards of 200+ dollars .
Apr 07, 2009 | Maytag HAV2557 Top Load Washer
Pav3200washer making grinding noise
The tub is supposed to be locked untill the brake is released. When the machine is in the wash mode the tub is locked or else the clothes would all get knotted up. When the motor reverses the brake is released and the tub can turn freely. Check the pump for bad bearing.
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
110 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
