Question about Sony Playstation 3 (PS3) Console
Ps3 wont turn on. when red light pressed light goes green for a second and fan starts light quickly goes yellow and then red
gamerfixer07
  • 344 Answers
SOURCE: PS3 does not turn on. When I press the on button, red light turns green thne to yellow then to flashing red.
This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
Posted on Jun 25, 2008
MNfisherman
  • 11896 Answers
SOURCE: 60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Posted on Aug 27, 2009
Testimonial: "I found out that I got the YLOD ( Yellow Light Of Death) Thanks for answering"
iplayb3yond3
  • 31 Answers
SOURCE: MY PS3 wont start up, everytime i press the start
That yellow light is what us gamers refer to as YLOD.. Its the Yellow Light Of Death. Your system will have to be serviced by Sony. If your system is under warranty still it wont cost you anything but if its not, Sony charges 150.00 dollars to fix/replace it. They will send you a box in the mail to send it to them. Turnovers usually 2-3 weeks. My condolences to you and your PS3. Best of luck to you.
Posted on Oct 24, 2009
Seth Wolf
  • 12 Answers
SOURCE: when i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Posted on Dec 06, 2009
  • 4102 Answers
SOURCE: my ps3 wont turn on. when the power button is
The PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
Let's start with the easy stuff first to narrow down the cause. Follow the steps below:
1. Assuming you were playing your PS3 when the YLoD happened, move your PS3 into an open area with a lot of ventilation and let it cool down for 20-30 minutes. Once it's cool, try to turn it back on and see if that helped. If not, go to Step 2.
2. Unplug all of your cables from the PS3 including the A/V and the power cord. Also unplug the power cable from the wall. Now try to plug them all back in and make sure they are all secure. Turn the PS3 back on and check if it's working. If not, go to step 3.
How to Fix PS3 Yellow Light on Your Own
3. Get a vacuum with a hose attachment and vacuum out the vents on the system. Sometimes dust build-up alone can cause your PS3 to stop working properly. You might also want to take one of those cans of air and blow it in there to get some of the stubborn pieces of dust out.
If none of those solutions worked, the problem lies within the PS3 and you will probably need to take it apart to fix it. The most likely scenario is that your heat-shield overheated, the chipsets got shifted due to heat, and your solder could be cracked.
the causes of the yellow light of death
Here are some of the top causes of the PS3 Yellow Light of Death:
* Overheating - The unit gets too hot. Sometimes caused by too much dust buildup in the vents.
* Blu-Ray drive failure.
* Bad power supply.
* Hard-drive critical errors.
* Hardware malfunction on the motherboard - The solder starts to crack due to excessive heating and cooling.
if you have warranty then take it back if you dont then you can either try the repair yourself how ever this is not very easy to do and can cause more harm than good you will need special tools to take it apart and its not easy you also need an understanding of heat seal paste and heat sinks due to this being the part you need to remove and put back
i do the repair for about 25pound plus parts so if you are paying someone to do it then your looking at least that price, i only charge if the problem is fixed so try and get the best price you can.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 18, 2010
I turn on my ps 3 and it goes green light then after about 3 seconds goes yellow then red.
when i turn ps3 on it flashes a yellow light then the green light comes on it dunt come up on screen and it wont turn off or eject disks
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 wont turn on. the red light on
PS3 owners refer to this as the 'Yellow Light of Death' or 'YLOD'. It's quite common. The problem is caused by poor solder joints (due to overheating) on the motherboard and degrading heat sink compound on the fan.
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont start up has a flashing red light
That happend to me and i gave it a rest for a couple of days and it worked again
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
When i power on ps3: light goes green to blue to red (3 beeps)?
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 wont start up, everytime i press the start up button it turns green for a second and then quickly turns yellow and shuts off
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
My ps3 froze during a game and now when i try to turn it on it turns green then after a few seconds it goes yellow and then starts blinking red. Whyvdoes it do this?
it does that because it has a hardware malfunction its known as the yellow or red light of death and as you can probably tell by the name its not good you wont be able to fix it yourself without further diagnostic testing but there are quick fix options on Google ive tried one method b4 it involves dismantling the console and reheating the cpu and gpu as this can be the cause but it is tricky hope that answered your question
Oct 01, 2009 | Sony Playstation 3 (PS3) Console
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
201 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
