Question about SmartDisk FireLite FWFL120 120 GB FireWire 400 (1394a) Hard Drive
What external power does SmartDisk FireLite FWFL120-N take?
My new computer only has 4-pin Firewire connector and 4-pin does not provide power like 6-pin. External SmartDisk FireLite FWFL120 Harddisk has external power input connector but no indications for voltage level or polarity. Manual provided by Verbatim (who bought SmartDisk) does not have power connector information. What external power voltage and polarity is required for FWFL120-N?
    New Friend:
    Problem Solver:
  • 5 Answers
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Posted on Aug 08, 2010
SOURCE:
HOW DO I CONNECT FWFL120 & 250 TO MACBOOK AIR?
Mac OsX users must install driver software into their MacBooks to use it. Go to the mfr's home page and download the driver into your Mac Air and it should work fine for you.
May 09, 2015 | SmartDisk FireLite FWFL120 120 GB FireWire...
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
Where can I find instructions for operation a model FWFL120-N FireLite SmartDisk
http://www.brothersoft.com/downloads/computer-manuals.html
you will have to type in the motherboard in the top search tab
or
http://help-site.com/c.m/
this site will tell you how to use something
hope this helps
http://www.9manuals.com/index.html
download after you pay
Jun 08, 2011 | SmartDisk FireLite 80 GB Hard Drive
When I plug my smartdisk firelite USBFLB40C into the usb port it says it needs to be formated. What is the problem?
If it is new and has not come pre formatted then you need to format it to match the system as it still could be in RAW state, but I would expect usb devices to be preformatted. (not always the case though)
A bit of history:-
FAT32 recognised by all windows systems ( but does not support files more than 4GB)
NTFS recognised by systems other than FAT32 (and supports files above 4GB)
FAT 32 was the native format for WIN98 but unfortunately when XP came along many companies continued to format in FAT32 for XP machines especially for the home user. (and XP would run quite happily with the format)
NTFS was and is the more stable of the two.
Jul 26, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
My firelite smartdisk model cord does not fit into my new macbook air. can i buy a cord that has a usb port at one end? thx
The MacBook Air has one USB port. Most computer stores have many different plugs on the other end that will fit your SmartDisk. Most of the SmartDisk units use the mini USB plug. It is the same as many digital cameras use.
Tiger Direct, and MicroCenter also have many different adapters, and adapter kits to use on all kinds of USB devices.
I hope this helps. Please let me know if there are any more questions.
AAirwolf
PS: I use a 160GB SmartDisk on all of my Macs, and PCs. Get way to move data without conflicts.
Feb 13, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
It seems the new macbook pro does not support the firewire connector. Is there a different wire available? It looks like the macbook pro has a firewire connection but it is much smaller than the original...
The problem lies in your cable!
The new macbook pro still uses firewire and will be compatable with your drive. It just uses a 4-pin instead of a 6-pin connector. You can get an adapter or new cable that goes from 6 to 4-pins.
They did take away firewire from the new line of plain macbooks though (shakes fist at steve jobs)
Feb 07, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
My smartdisk firelite does not appear anywhere on my computer
Sounds like you have a hardware failure either in the drive enclosure or the hard drive itself.
I suspect you may get lucky and find out it's just some of the circuitry in the smartdisk shell that is damaged.
Take the Smartdisk unit to your nearest PC shop and ask the technicians there to remove the Hard Drive and put it in a new enclosure to test it. If it works in the new enclosure, buy the enclosure and your done. If it doesn't work in the new enclosure then you may be suffering from worse issues that will require the help of a pro.
Either way let me know how you make out, if you need a pro for the next step, reply back with you location(Country, State, City) and I will refer you to the closest facility who can assist you.
Hope this Helps FixYa,
Chris
Aug 17, 2009 | SmartDisk FireLite 60 GB Hard Drive
Miising power supply
It takes a 5V adapter
Here is the part number
C14627 - AC ADAPTER FOR USB BUS-POWERED FIRELITE - ACFLB
Hope this helps!
Feb 27, 2009 | SmartDisk 40GB - 4200rpm - 40MBps - IEEE...
Center Pin External Power Polarity
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Jan 21, 2008 | FireLite (USBFLB80) Hard Drive
SmartDisk FireLite FWFL120 120 GB FireWire 400 (1394a) Hard Drive Logo
1,419 people viewed this question
Top SmartDisk Computers & Internet Experts
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Kris
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
