Question about Cfm 2000 Swamp Air Cooler MMB10 MasterCool Mobile Air Conditioner
The motor has burned out. I need a replacement. Where can I get a new motor?
  • 76 Answers
Unless you can find an HVAC shop with a NOS motor for this unit you will not find a drop in replacement. Even if you do get lucky and find a NOS motor be prepared to pay nearly as much for it as you would a whole new evap cooler.
That said, there are motors out there that will work, but you're going to have to make them fit with custom mounts.
It's still a little spendy, especially if you want two speeds like the original motor had, but you can get out for $80 or less if you're willing to settle for one speed (on/off).
boatandrvaccessories.com has a "Packard 40066" compressor motor for $69 plus $13 shipping. It may work but has only one speed.
Basically what you're looking for is a "48 frame", 1/8 hp, direct drive, 110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to give you flexability when mounting), "totally enclosed" or "open drip-proof" housing (NOT "open"). Rotation can be either CW or CCW as you can mount the motor on either side of the housing and some motors are reversable. If you've got the skill to custom make some mounts then you can probably fudge some of these specs. The ones you can't change are the 1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assembly simply can't be made to go much faster in that housing and if you try you will overheat the motor and burn it out very quickly (trust me on this one!). Most of the cheap motors I've found are 208-230v and I just don't see the point in having a small 220v PORTABLE evap cooler, that's just dumb.
After a LOT of online research I've found the following motors that would be a suitable replacement, with all the above mentioned specifications. I'm sure there are more, but cross referencing this information for someone not in the business is tricky and time consuming.
AdobeAir 1/8 HP 115V Motor for Adobe MMB10A RF031095 $116.66
http://www.comfortgurus.com/product_info.php/cPath/25_142/products_id/7451
Emerson 4856 (k055srj4796722b) (www.emersonmotors.com)
A.O. Smith 136A (UH1036NB) (www.aosmithmotors.com)
Magnetek 136 (now owned by A.O. Smith - www.aosmithmotors.com)
Fasco D733 or D261 (fasco.com)
Marathon X924 (www.marathonelectric.com)
AdobeAir RK232A check acehardwaresuperstore.com
Emerson K55HXKZT-9867
Grainger.com is a good resource but they are expensive.
The motors listed are suitable replacements, but have only one speed, "ON" or "High".
Packard 40066 - 115v 1075rpm $69 - SINGLE SPEED
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Good reading for selecting a replacement motor:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=13100
I suppose that if you found a smoking deal on eBay for an "Open" type motor you could try it, but I doubt it would last long and make damn sure that ****** is grounded well.
Posted on Sep 06, 2010
I am eplacing my home a/c blower motor myunit has a white wire my new motor dosent How do i wire it??
Assuming the motor has the same rating as the one your are replacing, almost all motors have a small schematic on the side.
I am not certain you have a good replacement blower motor due to the color of the wires. If the information on the nameplate data matches, then you are probably safe in going ahead and using it.
(Warning: remove all high voltage to unit before working on unit)
Two of the leads will have to be placed on the same connections as your old motor so trace them back to the control board and install the wire on the same locations. Most blower motor now days have capacitors on them. Make sure you have the replacement capacitor that your blower motor requires. It will say on the schematic on the side of your new motor what the size is. Typically somewhere around 3 to 20 MFD. MFD is short for microfarad. Capacitors are rated in microfarads and in order for the new motor to operate efficiently you must get the manufactures recommended capacitor. After you replace the motor and capacitor, on startup you need to measure the amp draw on the new motor to make sure you will not burn up the new motor. The amp draw maximum will be on the motors nameplate data and when operating, the amperage cannot exceed the nameplate data. If it does it will burn up the windings and stop.
If during any of this sound like something your not confortable performing, please call a competent technician to replace your blower motor. If you burn up the motor, the retailer that sold it to you will not replace it if your not a trained professional.
Hope this helps
Dec 09, 2014 | Heating & Cooling
Free chat line not
Usually the motor's piston burns up. You likely need to replace the motor. Yes, expensive, but probably less than a new snowblower.
Jan 05, 2014 | Toro Garden
What would make circuit board burn out in Andis AGP trimmers?
You need to replace the motor and the PCB. The motor is drawing too much current, that's what has wrecked the PCB. If the armature is a separate available part rather than a complete motor then it will be the armature you need.
Jun 25, 2012 | Andis Dog Clippers - AGP Super 2-Speed...
Motor is making a strange noise and smells of burning
The motor needs to be replaced. Unless your Henry is still under warranty it's cheaper to buy a new one.
Sep 20, 2010 | Numatic Henry Bagged Canister Vacuum
My mowers blades are not turning but the hum of the motor is there and it has a burning smell with smoke coming out of the motor housing unit ...help
It sounds like bearings are seized and need to be replaced. Too much attempted use will burn out the field windings and a rewind or new motor will be needed - both costly.
Sep 20, 2010 | Electric Lawn Mower
The dyson smelt of burning then stopped sudenly
Hi the burning smell is from the Motor. Your Motor has burnt out. You will need it replaced.
A new motor will cost around £40
If you would like us to advise you on how to swap the motors over then please order the motor and come back to us.
Thanks you
Aug 19, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
Have a 2007 mercury milan and the blower does not work i checked the fuses under the hood and one was burned out i replaced just to have it burn out again
Try disconnecting the wires to the blower motor before you put in another fuse. If the new fuse does not blow you need to replace the blower motor.
Nov 05, 2009 | 2007 Mercury Milan V6 AWD Sedan
Burning smell and smoke from motor
Sounds like the transmission is jammed.  This will cause the motor to bog and burn.
Nov 26, 2008 | Maytag Dependable Clean Top MAV5920EWW Top...
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Heating & Cooling Logo
1,092 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
