Question about HP G60 Notebook
My G60 does not turn. The only led that is lit is the one on the power jack. The battery charge led does not even shine. I've removed the memory, hard drive and wireless lan card to no available. I tested the AC Adapter with a meter and it seems to be fine. Please help..!!
    President:
  • 1,070 Answers
Welcome to FixYa
Make a Hard Reset.The hard reset will not delete saved files on the hard drive. Performing a hard reset To perform a hard reset, follow the steps below.
  1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
  2. Remove the battery from the notebook battery compartment.
  3. Press and hold down the power button for about 20 seconds.
NOTE: Holding down the power button while the computer is turned off drains any residual charge in the capacitors.
  • 4.Insert the battery and plug the AC adapter back into the notebook PC.
  • 5.Press the power button to turn the notebook PC back on.
OR
Try taking out the battery, and connect with the power adapter and directly plug it to the power source source to see if it can be boot up normally
OR
Try Re seating the memory{Remove RAM and Re Insert it] one stick at a time in each slot one at a time and make sure you try turning on the laptop after each reseat of the memory.....
I hope You got an Idea....Let me Know your Feedback.......Thanks for Contacting FixYa.....
Posted on Jul 05, 2010
  • 1 more comment
  • richard7@charter.net Jul 06, 2010
    Thanks for the ideas but I have done all of this without any success. Is there a way to determine if the power jack is bad?
  • shafi
    shafi Jul 06, 2010
    Check your Power Code for Any Physical Damage..
    Check with multi meter or Something like that..[Or Contact Technical Person]
    Change Power Code
    Check Power Socket[Check Pin-any Damage like Broken or bent]..
    For More Common actions to Solve Power Issues Click here....[For providing Detailed Instruction]
    You will Surely SOLVED....
    NOTE: Only Do if you have technical Experience or -on Your Own Risk...Dont make further Damage by Improper Handling.....So be Careful When doing Repair....
    Still have Problem There may be Motherboard Damage like Circuit break or Something else need Technical assistance.....
    Also Check Loose connections commonly occurs when a hardware component, such as memory module or bootable hard drive or disc, is installed improperly, or is not compatible with the computer, or the computer was dropped or jarred. Do each of the following actions and then attempt to restart the computer.
    If you have recently installed or replaced any components, such as adding more memory or a larger hard drive, do the following:
    Remove and then reseat any newly replaced components to verify that the connections are seated properly.Remove any new parts and reinstall the original components. If you install the new components one at a time, you can to determine if one of the new components is defective.If you installed multiple memory modules, remove the modules and then install one module in a memory slot and try to restart the computer. If computer does not start, move the memory module to other slot and try again. Repeat this action and test the other memory module in each memory slot.
    Let me know Result......Thanks for Using FixYa...
  • richard7@charter.net Jul 10, 2010
    So far, no luck at all. I put a meter to the power cord and it's fine. Is there a way to test the power board?
Power Supply issue?
So if the LED by the battery is lit that means hopefully your battery is good. If that's the case the laptop should boot off the battery if the Power Cord was failing. I think you've got another problem.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
If the Power Cord is bad:
Normally you will replace the power supply by the make and model of the computer, don't worry about the numbers on the power supply.
Just go to ebay at:
http://www.ebay.com
Jun 05, 2012 | Computers & Internet
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
Ok i got a hp g60-231wm and as i said in my last few post this is ongoing and i had no luck with figgureing out the solution,, now i did the steps that techiesguru Step 1: Hard Reset To perform a hard...
This sounds more like a defective charging circuitry on the laptop's motherboard. To save you time, my sole recommendation is to disassemble the laptop & inspect the motherboard for burnt or melted components near the power receptacle area. Any burnt or melted components will need to be replaced. If the damage is severe, you might need to replace the motherboard altogether.
You can refer to these 2 articles also if you would like to continue with the battery/AC adapter troubleshooting stuff:
http://www.fixya.com/support/r6416948-troubleshooting_laptop_power_failures
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Dec 04, 2010 | HP G60-230US Notebook
My laptop wont start even though the light indicator in the charger is on
You may first try performing the steps mentioned below:
1) Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook.
2) Verify the correct AC adapter is being used, and not a third-party replacement AC adapter.
3) Do not connect the AC adapter to a surge protector or extension cord.
4) If the DC jack on the computer is loose or damaged, the computer may require service.
5) Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged, or the LED is not lit or continuously flickers when plugged into a working AC outlet, the adapter must be replaced.
6) Attempt to turn on the computer normally.
7) Press and hold the Power Switch for 5 seconds.
8) Remove the battery.
9) Disconnect the AC power adapter.
10) Press and hold the Power Switch for 5 seconds.
11) Connect the AC power adapter.
12) Attempt to turn on the computer.
NOTE: If the computer turns on without the battery, connect and charge the battery for 24 hours.
13) Disconnect all external devices that are connected to the computer.
14) Attempt to turn on the computer.
15) Remove any additional Random Access Memory (RAM) that was installed in the computer.
16) Attempt to turn on the computer.
17) The troubleshooting steps listed above should resolve your issue.
If you have completed all of the steps and the issue is not resolved, service may be required.
Jul 06, 2010 | Dell Latitude D600 Notebook
Computer crashed and when I turned it back on the power jack leds flashed. Now even though my power jack is hooked in the red led is on as if the battery is not fully charging. what id this?
Remove the battery from the bottom.
plugin the power adapter and turn it on.
If it starts up normally you will need to replace the battery. If it will not turn on with the power adapter alone you will need to replace the power adapter.
Jun 24, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
G60-235DX PC Notebook: will not turn on, with battery that is charged or ...
Please perform the below steps :
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP G60-235DX Notebook
HP altec lansing Pavillon DV 6700 not powering
I am sorry to say that this is likely to be motherboard damage. The only other possibility is the the Power jack on the laptop itself is loose or shorted.
Either way.. You need a qualified repair.
The safe bet is a new motherboard.
sincerely,
Sagacious1
Aug 07, 2009 | Computers & Internet
HP G60 Notebook Logo
104 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
