Question about Mitsubishi WS-55859 55" Rear Projection Television
I have a WS 55859 and after power outage i got the green POWER light blinking. I replaced all seven capacitors 1000uf but i still can't switch it in? Any other advice? Rgds FM
    Problem Solver:
  • 10 Answers
Emmettsfixit's post might not be clear if you hadn't read the original solution he/she's talking about....
The flashing green timer light after a lightning storm seems to be a very common problem with old Mistubishi rear projection TV's. A friend and I had the exact same problem. And the following solution has appeared on numerous posts here and other websites. Thanks to Slinteriors who originally put the retail parts link:
Using this and other sites, I spent $36 bucks and a little time with a soldering iron to replace the capacitors on the DM board and got mine up and running (WS55859). I've never really worked on electronic circuit boards before, but the helpful advice at these sites got me up and running. Definitely check it out before you hire someone or replace your TV:
Repair Kit with instructional CD available at:
http://www.tvrepairworld.com/mitsubishi_repair_kits
for under $40 plus shipping.
Discussion of process in detail at:
http://www.hometheaterspot.com/showtopic.php?tid/137881/
for the WS55859 model, which may be a little different
Posted on Aug 03, 2010
  • 58 Answers
If replacing the 7 caps doesn't work I then try to re-solder the small 8 pin ICs. Be very careful and try to avoid cooking it or leaving a solder bridge. If that doesn't work either you'll have to replace the DM-POWER board. You'll beed a Mits authorized service center to order the part. Goodluck.
Posted on Jul 05, 2010
After a power outage the timer light on the front of the tv panel blinks but the tv will not go on. the owners guide states"If green light on frnt panel is plinking, please wait for at about one...
very common problem caused by failed DM capacitors. You can get the WS55859 DM repair kit from www.tvrepairworld.com which should solve the issue. The kit contains the upgraded caps and the CD with repair instructions.
Feb 16, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Powe will not turn on the timer is blinking green
the problem on ur tv is the control box ( hd tumer ) , the way to fix this problem is by replasing the 7 capacitors on the power supply on this box which is locate next to the tv chasis look like a cable box inside the tv , when ur take this box out open and u woulse a small power supply u most replace this 7 capacitor 1000uf 10-16volts and also solder the connector , that sould fix this problem i already fix 20 tv with the some problem
Dec 07, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Green blinking light following a power outage
I rebuild the DM power supply in these sets with about a 50% success rate. Sometimes changing the 7 1000uf caps on the small power supply in the DM will fix it, you'll also have to solder the small 8 pin ICs as well. Do this carefully as you do not want an accidental bridge. If this does not fix your problem, replace the DM-POWER board not the DM Assembly. It's about a 300 dollar difference. You'll need a mitsubishi authorized service center to order the part for you. Goodluck.
Jul 05, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Power was off
You need to replace 4 capacitors on the DM board. It is located inside a metal box on the left side of the set, looking from the rear. The original parts are 1000uf 16v. You will need to install 1000uf 25v or 35v. They are located at the top of the board and are green colored.
May 28, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Blinking green light will not power up
My WS-55859, Did the same thing. Power went out, when it came back on the green light in front of TV would blink, but TV would not power on. Did some googling and saw multiple posts for "blinking Green light" or "Blinking Green light of death". Most of the posts pointed to replacing capacitors on DM Power board. I followed the direction and it worked great. Note the TV shop guy who did the soldering for me said the capacitors "looked fine" and they were not the problem. I couldn't tell the difference between a good or bad capacitor, so I asked him to swap them anyway. He did, I plugged the board back in, buttoned up the back of the TV. After 60 seconds Green light stopped and I started watching TV again... Here is the link to the best instructions I found (http://hdtvoice.com/voice/showthread.php?t=32186).
Aug 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Set does not turn on. Green lights continually blink.
you need the DM repair kit to rep[lace the bad capacitors on the DM power supply. You can get the V21/V19 DM repair kit at the following link which contains the replacement capacitors and the Cd with detailed instructions for the repair with clear instructions and pictures. heres the link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
TV Won't Power on Green Flashing Timer Light
The green power light is continually flashing and the tv will not turn on. I hit the reset button and nothing happened. I have exhausted all other troubleshooting methods. Please help, what should I do?
Feb 08, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Flashing green light
I have the same problem and I don't know what to do>
Dec 30, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
308 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
