Sanyo high definition tv
Our screen goes black after a very brief white flash - then we have only audio no screen??????
  • 563 Answers
Hi there
Could you please supply me with the Model of this Sanyo TV ?
Posted on Apr 18, 2008
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Sanyo model 42848
This could be a faulty back light lamp.It is located right at the back of the screen It is an cold cathode lamp supplied by a high voltage from inverter board .Inverter board has a input voltage of 24 volts inverted into 300 volts AC this lamp lights up the screen...
You need to open the back cover to check the lamp.....
Jun 06, 2012 | Televison & Video
A brief flash of picture then black
A brief flash of a picture few sec. and the tv LCD screen panel go black.The tv still have audio sound left?Yes,tv have 1 or 2 the long board that call the LCD inverter boards it is dead.The inverter boards only job are too provided a backlight for the tv LCD screen panel to see a picture.
Aug 28, 2011 | Proview HX303 30 in. HD-Ready LCD...
HOW DO I CONNECT TO TV
There are many methods to do this.
If your cable are ONLY RED,WHITE,YELLOW
1 Plug the red white and yellow cables to there corrosponding jacks on your DVD player
2 Plug the red white and yellow cables to jacks labled video IN, Audio IN. They will be colored on the back of your Tv
3 Plug in the power cable.
4 Turn it on and flip through the inputs on your tv until you see the picture
IF your cables are RED, GREEN, BLUE, RED, AND WHITE
1 Your are using what is called conponent video. This is a high definition video.
2 Three of your plugs are for video. They are Red(Cr) Green(Y) and Blue(Cb)
3 Plug the GREEN into the Y jack
4 Plug the RED into the Cr jack
5 Plug the BLUE into the Cb jack
6 Plug your power cable int o the wall if you havent alredy done so
7 Plug the other red cable into the audio right jack
8 Plug the white cable into the audio left jack
9 Turn it on and surf through the input until you find it
If you have a BLACK, RED and WHITE
Do the same as RED WHITE and YELLOW but
1 Put the black cable into the s-video slot
2 Surf through the inputs until you find the picture
If you have ONE BLACK CABLE
1 This is called HDMI(High-definition multimedia interface)
2 Plug one end into the tv and the other inte you dvd
Thank you for your time, Good luck and I hope this works
Jun 08, 2011 | Televison & Video
Zenith tube tv has thin white lines but no picture and I can hear audio
Hello jreese, Hi, Most definitely its a horizontal output problem, your tv has no horizontal deflection to pull the screen vertically, the power transistor that produces the high voltage is bad, this needs to be replaced. definitely you always have sound, the audio section is a separate block from the high voltage block, go look for a technician to have this checked.
Mar 03, 2011 | Zenith B36A24Z 36" TV
Sanyo 46' flat screen tv - has issues like all of a sudden it will make a high pitched noise and then the TV goes out - the picture freezes and then the screen goes black
our Sanyo Flat screen tv freezes, makes a loud noise, then turns off then back on automatically. It does it more frequently while watching an exciting part of a movie
Jan 10, 2010 | Sanyo DP46849 46 in. HDTV
Sanyo vizon tv black screen
Replace 12v ac adapter ( if you can find one ).
Nov 30, 2007 | Sanyo Vizon LCD-15A2 Television
Sanyo DS31520 31" whining, high pitch screech, very annoying!
two audio out RCA type lacks a red and white. only thing I can think of is make sure nothing is connected to the outputs unless your running it to a stereo. now for the inputs are 3, video yellow ,left and right audio is white and red, make sure the yellow has yellow input rca plug. still problems take them all loose and see it feed back goes away.
Dec 22, 2006 | Sanyo DS31520 31" TV
114 people viewed this question
jasbo
jasbo
