Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
Disassembly instructions for impeller to replace bearings for pump Model # PF-40-2N22C
3 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a Waterly Executive Pump PF-40-2N22C\r\nI
Waterway did change the wet ends slightly (the difference is only minute and you wouldn't realise without meausring) and if yours is the older version you may need to change the entire wet end.
I'd advise you to take the pump to someone who can advise you and perhaps consider changing the entire wet end so that you have a new mechanical seal too.
If you're in the UK I can possibly help but I suspect that you're in the US...
http://hottub.synthasite.com
Regards,
Ian.
Posted on Jun 18, 2010
SOURCE: How do you take this pump apart so you can replace
I just did this.
Take the screws off the outer cover fo the wet end. That will expose the impeller.
At the other end of the pump is a small metal cap in the middle. Pry that off with a screwdriver. That reveals the shaft of the motor which has a slot in it. This allows you to hold the shaft still with a large screwdriver.
While someone holds the shaft with a big screwdriver, you rotate the impeller counter clockwise to unscrew it off the motor shaft.
In my case the impeller was so caked onto the shaft with rust that we could not loosen it. We broke the impeller and still could not unscrew it. The screwdriver keeps jumping out of the slot in the shaft.
So the next step was to take the shaft out of the motor. On the far end of the motor are 4 small looking bolt heads. Undo those. They go right through the motor into the 4 legs of the wet end.
Stand the motor up with the wet end up. Pull hard to pull the wet end motor cover off the motor and you will then have the wet end and armature of the motor in your hands. Heavy.
Place some wood into a large vice and then grip the big silver part of the armature in the vice. Then unscrew the impeller.
I got this far tonight and the bearing at the wet end is hard to turn and is the reason for the failure of the pump. I am not sure of the bearing can be pulled off without special equipment.
Posted on Jan 27, 2011
Find replacement impeller for Wayne pump YCB139
some pumps can be fixed if, disassembled properly in the first place. and last for many years. soo that said, search your area for your local electric motor repair shop with free testing, bring it in and see if they might have a used impeller, new shaft seal and the bearings, to get you up and running again. REMEMBER TO PRIME THE PUMP AFTER THE REPAIR ! most all pumps need water in them to work
Jan 31, 2015 | Pool & Spa
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
Hobart LXiH error E4 AND part makes noise when OFF
test this steps and fix it. GOd bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 22, 2013 | Hobart Dishwashers
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
How to replace bearings
Must disassemble the pump from the motor. The impeller has RH threads so hold motor armature (do not damage it) and turn impeller CCW to remove it from end of shaft. Hold armature in left hand and rotate impeller with right hand, turning hand on impeller back toward your body, or top of impeller toward you. Don't know how else to describe it. Once you have the impeller off everything should come apart pretty easily.
If impeller is really stuck, you will need to figure out how to hold it evenly all the way around without putting pressure on blades. Strap wrench, home made jig, something that can put more pressure on it than your hand.
You may want to remove the motor field so that you can grasp the armature while removing the impeller, do this by removing the long screws from the end of the motor.
Gently pry, tap, slide, however you can, get the bearings off the armature shaft without damaging any parts attached to it like fans, or starter centrifugal weights. Those things can be removed if needed.
Put new bearings on by sliding over shaft and seating in place by driving against the center race only. Do not drive bearing on by striking the outer race to move the inner race, this will damage the bearing.
Aug 14, 2012 | AO Smith SQ1152 Pool Pump Motor
Need to change the seal on a PF-50-2N22C
Thank you for posting your question here on Fixya.com.
In general the process is the same for any brand...Disassemble the motor from the pump, lock the motor shaft at the end opposite the pump, spin off the impeller (which may be covered by what is called a diffuser), replace both halves of the seal (one is pressed into the pump housing and the other rides against or on the back of the impeller) and assemble in reverse order. If you need more specific directions, please add a comment with your question(s) or contact me using our web site at www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 03, 2011 | Waterway 5HP Executive 56 Frame Spa Pump...
My Whisperflo Pool Pump is making a racket. Is
Stick a large screw driver on the motor in the area of the bearings and on the pump housing ... stick the handle to your ear (notice I said to your ear ... not IN your ear) Listen. Often you can determine the source of the noise in this manner.
My money is on the impeller. You will need to replace the seals when you disassemble the pump motor from the pump housing. I found a dime in the impeller recently ...it made a racket until the impeller wore down in that area.
May 02, 2010 | Pentair 1.0 Hp Whisperflo Pump
I turned my starite pump on and it just hummed for about 5 seconds then cut off. What could be wrong?
Your pump motor or impeller is seized. Disassemble the pump housing and check the impeller to see if it spins freely. If not then check for debris, if impeller appears to be free of debris, then check the shaft seal and motor. If the shaft seal is leaking water, then the motor bearing is likely rusted and will need to be replaced. There are 2 bearings, replace them both along with the shaft seal
Apr 11, 2010 | Pentair STARITE PUMP HOUSING / TANK BODY
My Hayward just hums when I turn it on and after a few seconds the breaker pops.
You will need to disassemble the pump and check the impeller. remove any debris and try turning the impeller by hand. If it does not move or is dragging, you will need to overhaul the pump. Possibly a shaft seal leak has damaged the motor bearing(s). Replace the shaft seal and motor bearings. If the motor is badly deteriorated, you might need to replace the motor. Note... the impeller turns counterclockwise to loosen. you may need special tools to grip and hold the motor shaft and the impeller to prevent damage to the impeller. If the impeller is seized on the shaft from rust, you may have to break it to get it off. reassemble with teflon lubricant on the shaft threads when reinstalling the impeller. This will prevent seizure later.
Apr 10, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
666 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
