Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
My ice maker seems to have a problem with the hopper corkscrew. It will sometimes push the ice out ( mabey 1 out is 20 trys.) You can hear it accuate when the lever on the front is pressed but the screw wont turn
  • 3,083 Answers
This has happened before to people. After some intensive research, I found the identical problem, and what you need to do to fix it. Here's the web page, scroll down beneath the video to read the answer:
http://fixitnow.com/wp/2006/04/01/icemakers-in-frigidaire-refrigerators-stop-making-ice/
Posted on Jul 05, 2010
My Kenmore refrigerator side by side ice will not come out of door
Sounds like where the Ice comes out of the ice maker sometimes gets clogged with ice look inside that little Hopper the goes into the door and see if it has Cube's jammed in it
Jan 08, 2016 | Kenmore Side by Side Refrigerator
Ice dispenser not dropping ice using dispenser knob
If you can hear the auger motor turn, you may have a large chunk of ice in the hopper.
Jul 25, 2014 | Kenmore Refrigerators
What ice when pressing ice button
There should be a pin in back of the corkscrew that fits into a channel on the motor. You'll have to remove the bin to see the fittings I've described. Rotate the corkscrew so that the pin will fit between the "paddles" of the channel that is on the motor and replace the bin. The corkscrew won't turn unless these two parts are properly aligned.
Sep 09, 2017 | Whirlpool WRS325FDAW 25.4 cu. ft. Side by...
Our ice maker has rust on ice sometimes and can't understand why or how to fix
You would need to remove the ice storage bucket and dump the ice, check the corkscrew wire in the bucket for any signs of rust, some auger wires were chrome plated and not aluminum. If no rust there, remove the ice maker it's self and check the ice making mold for signs of rust. Replace all rusted parts found. Pleazer Appliance...
May 06, 2014 | Frigidaire GLRS237ZA Side by Side...
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
My freeser is not making ice
If it just plain stopped making ICE then obviously the water source must still be connected, but it could be that the piping where it comes into the back of the FREEZER compartment could be frozen. If that is the case, simply take the ice maker out, the tubing will come with it. Rinse it out, warm water and reinstall. Sometimes the ICE THAT IS WAITING to be dumped into the ICE hopper will not dump correctly into the hopper, so in that case, just reach up in the ice maker and jiggle loose/out all the loose ice and sometimes it will start working. You may try jiggling some of the solid ice that is still in the ice maker, as it may have jammed the ice maker when it expanded when it froze. Be gentle in all cases, do not get harsh with the machine and success should be yours with 30 minutes to 60 minutes maximum work. Cheers................ :-)0774a49.gif
Dec 01, 2009 | Refrigerators
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Jan 25, 2008 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
50 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
