Question about GE DVLR223 Dryers
My dryer only lights the first time.
I have a GE 7.0 DCVH515GF1WW propane gas dryer. When you first start the dryer it lights, but then the gas valve will not open again until you shut off the unit and wait at least 10 mins. The igniter is getting power (you can see it glow) but it will not light pls help
  • GE Master
  • 43,501 Answers
Hi, If you have a gas dryerMy dryer only lights the first time. - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems..My dryer only lights the first time. - 2_bing.gifck out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
Gas dryer won't light
Check the gas valve with a meter for coil resistance and voltage, there is a delay from when the ignitor comes on and the gas valve opens.
Apr 14, 2017 | GE Dryers
How do i get into the dryer to convert from natural gas to propane. there are no instructions on how to get into the dryer
you need to cahnge the orifice in the gas valve. any harware store or appliance store sells them.
Sep 14, 2011 | GE DBXR463GB Gas Dryer
I have a hayward H400 serise propane heater. I replaced the gas valve. When it goes tot turn on it takes about a minute then starts clicking to ingnite the gas. SSoem time it lights but then goes out other...
0. Check the spark ignitor conection to the board
1. Check the water by-pass valve if you have it
2. Check your gas pressure. (5-7"wc for natural gas, 9-13"wc for propane gas)
3. Clean your filter for your water system or remove it and try again
4. Check the Hi-limits on your heater
5. Replace the thermostat
May 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
Gas dryer on, won't heat, just had propane delivery,tanks were em
I hope you didnt blow up by now, but your to hold a pilot valve down while igniting it
and keep down for 1 minute then release then turn valve to keep the pilot to operate the valve
Jun 18, 2009 | GE DBXR463GB Gas Dryer
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
GE Gas dryer getting too hot
The gas burner valve is not the correct one for LP gas. You have to convert the valve as well as the orifices. The clicking is because it is over heating and cycling on and off o the high limit (safety thermostat)
Dec 18, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
COnverting it to propane
You need to change the orifice on the end of the gas valve and flip the cap on the regulator to the LP side. Model number would help.....?
Oct 30, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
LG gas dryer to convert in propane
If you replaced the orifice on the gas valve, then you must screw down on the adjustment screw on top of the valve.  Use a flat screwdriver and screw down the pressure adjustment screw till it stops in the down position.  Then the valve is set for propane use.
May 05, 2008 | LG WD-3243RHD Front Load Washer / Dryer
GE DVLR223 Dryers Logo
163 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
