I have a Scott 32" LCD TV.When I go to turn it on the Red LED on the front dims for a second and stays red.I also hear a very High pitched squeek.I tried unplugging it and it worked but I don't want to have to keep unplugging it to watch TV.Any suggestions would be great.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Red light means that the power is getting to the unit however, as its not working which means that the power board should be checked. To start with open the back of the unit and then check the power supply board for any bad (bulged/swollen) capacitors. Power supply board is the board where all the power cords/plugs goes into. After you have checked that also check the main board and if you can use a multimeter to test the components on these boards. However, from your earlier posts it seems to be the main board that is bad and should be replaced. All this should only be done if you have knowledge of internal circuitry of the unit as the components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 05, 2010
My Scott LCT37SHA TV will not turn on. I am
IF THE TV NO TURN ON THE FRONT LED IN RED CHANGE ALL 470 MF& 1000MF CAP IN POWER SUPPLY, FUSE AND VARISTOR DOWN THE BOARD. IF THE FRONT LED TURN ON IN RED ONLY CHANGE THE CAPACITORS.
Apr 04, 2010 | Scott LCT37SHA TV
No sound, no picture
If by catscan sound you mean a high pitched whine? That usually indicates that the power section has had a part fail. The capacitors on the main board will cause this. You can take it to the shop but get an estimate first as the repair cost can be close to replacement as the prices keep falling. The repair parts are pretty cheap but the labour isn't.
Jul 24, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
I have a 32 Akai HD TV I found the following problem when I returned from vacation The red light is showing. I press the power button, the green light comes on for a short while and then goes back to red....
Symptoms of a Defective or dying Power supplies on LCD TVs. 1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc. 2. TV not turning ON properly. 3. TV turns OFF by itself. 4. Needs to be unplug to many times to make it work. 5. Humming or high pitch noise heard through speakers or at the back of the TV. I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jun 12, 2009 | Akai LCT3201TD 32 in. LCD Television
Akai lct3201ad red standby light turns green then red again!
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
TV connections- Wii, Direct Tv and DVD palyer
Hidden switch for output coonections on back panel of dvd player.
Dec 27, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
32" scott
your tv has suffered esd damage. likely control board.
Dec 07, 2008 | Akai LCT3201AD 32 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
