Question about Radio Shack Pro-2096 Base Scanner
Pro-2096 Digital trunking mobile/ base scanner
No screen !!
This is happing to most of the units and radioshack wont admit it.
Posted on May 01, 2008
My pro 2096 has no volume
  • You have to uses external software on this scanner.
  • Custom GRE/Radio Shack Frequency Table
  • Table 1 ---
  • With WIN96 software for the PRO 96/2096 scanner:
  1. Prompt "MULTI TABLES"
  2. Prompt "EXTENDED TRUNKING TABLES"
  3. Do not prompt any "STANDARD PLANS"
  4. "CH LOW" 8192 "CH HI" 12287 "BASE FREQ" 453.0250 "OFFSET" 8192 "STEP" 12.5
  5. "CH LOW 12288 "CH HI" 16383 "BASE FREQ" 450.0000 "OFFSET" 12288 "STEP" 6.25
  6. Clear all other trunking tables, and prompt "OK"
  7. Now save your file.
  • Custom Uniden Frequency Tables
  • Table 1 -
  • Base: 452.0000
  • Space: 12.5
  • Offset: 380
  • Table 2 -
  • Base: 460.0000
  • Space: 12.5
  • Offset: 570
  • If you have not done this then you will receive no audio on digital reception.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 06, 2011 | Radio Shack Pro-2096 Base Scanner
Local police, sheriff and fire are not received anymore, but can pick up distant city police, airports and hwy patrol. Have Pro 2096 model and have not tried any fixes.
With the distant services still coming in, it's probable that your local agencies have changed from single-frequency operations to a trunked system or, if already trunked, that frequency/user assignments have been updated within the system. For the latest on active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Shack Pro-2096 Base Scanner
Unlock code all frequencies for pro 2096 digital scanner
Sorry, but there is no magic code that will "unlock" your Pro-2096 or any other modern scanner. If you want a scanner with wider frequency coverage, you'll need to purchase one that comes that way from the factory.
Bill B.
Oct 07, 2010 | Radio Shack Pro-2096 Base Scanner
800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
My pro-2096 does not display any letters or
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
I HAVE A PRO-2096 DIGITAL TRUNKING BASE SCANNER. IT HAS WORKED FINE BUT NOW IT READS " ALL CHANNELS LOCKED OUT " NEED HELP
need to do a RESET. Then try your local WX frequency to verify it works. The RESET will wipe out all existing programming, just to warn you. Check your manual, or RadioShack.com for details.
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
How do i reset frequencies on a scanner /delete frequencies
You listed your question in the PRO-2096 section, so this response applies to that model. If you have a different scanner, please let us know the make and model.
The PRO-2096 is an advanced scanner capable of monitoring both single frequency conventional systems and advanced trunking radio systems. Programming methods are detailed and lengthy and cannot be reproduced here. For specific programming instructions, please see the scanner's operating manual, which can be downloaded/printed here:
http://pdf.textfiles.com/manuals/SCANNERS-F-R/Radio%20Shack_PRO-2069%20Wideband%20Scanner-Reciever_Manual.pdf
If you have questions regarding a specific feature or problem with the scanner, please let us know.
Dec 20, 2009 | Radio Shack Pro-2096 Base Scanner
Can I upgrade to recieve marks system.
If you mean the State of Ohio MARCS system, then you need a digital trunking scanner. The Radio Shack Pro-96 and PRO-2096 will work as will the new GRE 500/600 units and a couple of Uniden Bearcats. They must say "Digital Trunking" or "P-25" for it to work on Ohio MARCS.
Aug 04, 2009 | Uniden BC248CLT Base Scanner
hello,
Open the mobile and the refix all the connection inside maybe some loss connection make it faulty.
best ,
melnavz
Apr 29, 2008 | Radio Shack Pro-2096 Base Scanner
Radio Shack Pro-2096 Base Scanner Logo
156 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
