Question about McCulloch Garden
Clutch cover smoking
Mc culloch 338 clutch cover smoking
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain and wash out the clutch internals with spray carburetor cleaner. Clean the side of the engine case, start the engine and watch for oil oozing out of the side port. Clean the bar drive-end small oil passages that go out to the chain groove on each side and clean the entire chain groove. If oil came out of the engine side port ok, then re-assemble the bar and chain, but leave the cover fasteners only finger tight. Tighten the chain so that the chain comes up to the bar, but not so tight that the chain can't be pulled by hand. Tighten the cover fasteners and recheck the chain tension. Make sure the chain teeth cut toward you on the bottom run and that the chain is properly sharpened. Hope this helps!
Posted on Jul 11, 2010
What kind of fuel i need for my older mc culloch chainsaw-1:25 or 1:50?
To be on the safe side i would use 25-1, it will not harm the machine, just smoke a little more.
Sep 17, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mc Culloch power washer FH140A The "on/off"
easiest way to fix it, buy a new switch at a home improvement center, the two metal piece go on the bottom and the springs are on top of them, when the switch is in the off position the metal pieces are up off the contacts on the bottom and when on the on position the metal pieces make contact. Hope this helps Tim
May 28, 2011 | McCulloch 1400 Psi Electric Pressure...
Mc culloch trimmac 250 LS triming head is only rotating very slowly and stops when i go to strim there does not seem anything wrong with the cable between the engine and the cutting head
It certainly sounds like an issue with the flex drive, or maybe where it fits into either the gear head or the clutch drum, it may have rounded the inner connection where the flex drive fits into.
May 01, 2011 | McCulloch Garden
Mc culloch tm 250 strimmer. petrol/oil ratio
40 parts fuel to 1 part 2/stroke oil
Aug 05, 2010 | Garden
What are the carb. adjs. on a Mc culloch chain saw model cs 38em
If it bogs down like it's getting too much fuel, turn the low side screw out about 1/8 of a turn at a time until it will rev without bogging. If it chokes down like it's not getting any fuel, you probably need to open up the high screw a little.
BTW, you can determine which screw is which by looking at the carb at the base of the screw...it will have a L for Low or H for High stamped near it.
Jul 18, 2010 | McCulloch Garden
Mc culloch chain saw 742 manual need urgently
Both the OM and IPL can be found here:
http://www.mcculloch.biz/int/support/owners-manuals/
Just type "742" in the "Model Search" window and click Search. HTH
Lou
Feb 17, 2010 | McCulloch Garden
After having my Mc Culloch sharpened
You may have the chain on backward. The teeth on the bottom of the bar have to have the sharp edge coming at you in order to cut anything. Hope this helps you, Jeepfxr
Jan 28, 2010 | Garden
What is the oil-gas ratio and the bar oil for a Mc Culloch Mac130
You should be safe with a 32:1 mixture unless you are a logger. And any Bar Chain Oil should work fine.
Apr 15, 2009 | McCulloch Garden
Garden Logo
106 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
