Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Don't know exactly where to drill a hole to refill Epsom T0711 printer ink cartridge. Can you help?
    President:
  • 1,194 Answers
Thanks for using Fixya.
You won't need to drill hole anywhere.
Visit this link to get all the instructions required to refill the ink in Epson T0711 cartridge.
But remember you would need a chip resetter gun to re set the chips on the ink cartridges after you refill the cartridges.
Visit this link to buy Universal chip reseter if you don' t have.
Good luck and have a nice day.
Posted on Jul 05, 2010
  • Ranglo
    Ranglo Jul 05, 2010
    Can you tell me what was the problem with the above solution.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 31 Answers
~ There is a unique chip set in each cartridge and if you use non Epson inks chances are you can damage the printer. Each time that you are replacing the inks you are also replacing the Nozzles. It has separate nozzle for the inks. Also, you may experience output issue regarding the usage of the non Epson inks. Epson doesn't exchange inks which not Genuine Epson Cartridges. Warranty of the printer is voided if you tamper the ink cartridges.
Posted on Jul 06, 2010
I need to know how to refill my ink for my nx110 printer
The ink cartridges used in Epson's Stylus line of printers are very similar to the ones used in its other printers. A handful of cartridges--like the S020034, S020047 or S020049--may require a slightly different refilling technique, but they all basically entail opening a fill hole in the top to run down into the ink chamber within. Once the chamber is accessible, you can use a basic refill kit with a syringe bottle to refill the chamber, as with most printer-ink cartridges.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
1. Hold the cartridge upside down so the outlet holes to the printer paper are on top. Cover each hole with a piece of tape, then turn the cartridge right-side up.
2. Make a hole in the top of the cartridge above each ink chamber. For most cartridges, simply poke a hole through the label with a toothpick. With cartridges like the Epson Stylus 34 (the casing of which is black), pull back the label to reveal the filling holes and puncture the seal of each home. For the 47 or 49 color cartridge, drill a 1/8-inch hole in the shell between the label and front edge.
3. Determine which color of ink is in which chamber (if you're refilling a color cartridge). The toothpick used to puncture the hole should draw out some ink to show you. If you have a cartridge in which you punctured the label directly, the order of the color chambers is usually cyan, magenta and yellow. If you created the hole in another way (like with the 34, 47 or 49 cartridges), the order is usually magenta, cyan and yellow.
4.Fill the syringe bottle with 5ml of ink. Insert the needle in the filling hole and inject the ink. There may be a sponge inside the chamber, so make sure the needle goes all the way through to the bottom. The 34 cartridge takes up to 12ml of ink.
5. Tape over the fill holes you created. If you drilled the holes, plastic plugs (like the ones included in a refill kit) can work as well. Leave the tape on the outlet holes as you replace the cartridge in the Epson Stylus printer.
6.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Tip
How to Refill the Epson R340's Ink Cartridge
<span>Instructional steps<br /></span> Things You'll Need: <ul> <li> <span>Syringes</span> </li> <li> <span>Refill ink</span> </li> <li> <span>1/16 inch thumb screw</span> </li> <li> <span>Paper towels</span> </li></ul> <ol> <li> Place the cartridge on a flat surface over some paper towels to soak up any spilled ink.<br /></li> <li>Drill a hole directly above the "H" in the word "Push" on the top label.<br /> </li> <li> Drill a hole above the the first hole so air can escape while you are filling the cartridge.<br /> </li> <li> Fill a syringe with the correct color and amount of refill ink. The black cartridge holds 25 ml of ink. Color cartridges hold 10 ml of ink.<br /> </li> <li> Insert the needle of the syringe into the first drilled hole. Slowly inject the ink into the cartridge.<br /> </li> <li> Replace the cartridge into the Epson R340. Allow it to rest for 24 hours so the ink can absorb into the sponge inside the cartridge.please rate this post by saying how helpful it is to you<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_7414161_refill-epson-r340_s-ink-cartridge.html#ixzz13r3MVnYc"><br /></a></span>
on Oct 30, 2010 | Office Equipment & Supplies
How to refill a canon lbp 2900 printer cartridge
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. 2
    Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. 3
    Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. 4
    Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. 5
    Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. 6
    Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Nov 10, 2010 | Canon LASER SHOT LBP-2900 Printer
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
Want to refill ink cartridge but don't know where to inject ink.
Check this out:
www.disc-info.com/downloads/jr-refill/epson/jr-epson-t0711.pdf
Feb 25, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do i refill a canon printer cartridge
You need to put a strip of fexible eletrical tape over the large ink pad hole on the bottom front of the cartidge.
Drill a small hole at the top of the ink cartridge over the ink reservoir. (most refill kits come with a small bit to drill the hole). Fill the ink reservoir to 3/4. Put a piece of flexible electrical tape over the drilled hole to close the hole.
Voila! ... a refilled cartridge.
Most refill kits will have instructions.
Refilling can be messy so be careful and wear disposible latex gloves to avoid staining your hands. Also make sure you work over newpaper to catch any ink that you may drop.
Good luck.
I found that aftermarket cartridges are less than half the price of OEM cartridges and without the mess.
Aug 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Refilling ink Cartridges
There is a service hole on the cartridge that u need to unplug with a small drill bit or some type of hole puntch. Then u need to cover the hole with the stickers it came with..
Apr 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
How to refill printer cartridge
Hello, it is always a bit offputting the first time you go to do it, but once you have you will not look back, you save so much money. I only go throught 3-4 cartridges a year now i refill and amazingly i get 7-8 refills each cartridge on my lexmark x1185
Please describe your cartridge, does it have alittle plastic cover over top?
Feb 16, 2008 | Brother MFC-440CN InkJet Printer
T0711 cartridge for epsom dx8400
yes, T0711/T0712/T0713/T0714 can be refilled and reseted. I've just bought Epson DX8450, and found here in Romania a reseter for this chips, for about $8
Jan 22, 2008 | Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
374 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
