Question about Polaris Trail Princess
HELLO.. MY DAUGHTERS POLARIS TRAIL PRINCESS STALLS WHILE GOING UP HILLS. THE BATTERY SEEMS TO CUT OUT, AS THOUGH NOT ENOUGH POWER TO MAKE IT UP A SMALL INCLINE.. I CAN UNDERSTAND THIS, HOWEVER THE BIKE ROLLS BACKWARD AND SHE IS UNABLE TO PUSH THE PEDAL DOWN AND STOP OR RESTART THE BATTERY UNTIL THE BIKE COMES TO A STOP.. THE ROLLING BACK PART SCARES ME! MY SONS GATOR, WHICH MAY ALSO NOT MAKE THE INCLINES SOMETIMES, THE TIRES WILL SPIN BUT THE BIKE WILL NOT ROLL DOWN THE HILL. THE BIKE WILL LOCK ITS TRANSMISSION.. TtHE TRAIL PRINCESS WILL NOT... SCARY!! ANY SUGGESTIONS OR OTHERS WITH SAME PROBLEM?? THANK YOU!!
    Genius:
  • Polaris Master
  • 1,508 Answers
Sounds like the foot pedal might be bad, when she is driving forward and lets off of the pedal do the rear wheels lock up or does it keep coasting?
Posted on May 06, 2012
  • 19 Answers
SOURCE: Rear wheels-
Both wheels should spin in 2nd gear. Only one wheel may spin in 1st, but if you put a little pressure on the one wheel that spins it should make the other wheel start spinning.
But both wheels should spin in high gear at the same time.
Hope this helps. If there is more help you can also ask these guys at this website. http://www.shopjandl.com/ I get my parts from them and they seem to also work on them as well
Posted on Apr 21, 2009
  • 156 Answers
SOURCE: Peg Perego John Deere Gator not working at all
It sounds like you need a pedal switch or it has a loose connection in the wires. It is a specific Peg Perego Switch that will fit under the foot pedal. I have a gator that was doing the same thing so i replaced the shifter switches and the foot pedal switch, but I bet you could start with just the foot pedal switch.
I bought mine at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html but you could also call them as well.
Hope this helps
Posted on Apr 30, 2009
  • 156 Answers
SOURCE: Gator- goes a few feet & then cuts out.
It sounds like the thermal fuse is being kicked on under the shifter. The wires might be loose on the motors in the back, or the motors themselves are getting hot causing the fuse to trip.
The gator as a specific peg perego shifter assembly that has been upgraded with the wiring as well.
I would contact the guys at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html I have a few of these toys and these guys have always been helpful. Hope this helps
  • 156 Answers
SOURCE: older gator 4x2 was running fine all the sudden just stops
I would check to make sure the shifter and switches are making contact.
I replaced mine at this site
http://www.shopjandl.com/asgi0115nyr.html
but you can also call them toll free or email them. I have several of these vehicles for my grandkids and these guys always help me out.
Hope this helps
Posted on Jun 15, 2009
  • 156 Answers
SOURCE: My sons gator will not drive both back wheels all
Have you checked the connections on the motors? I had the same problem because the wires came off of my gransons, but then I ended up replacing the switches.
You can get them at
http://www.mypegperegoparts.com/switches.html
and you can also call them if you need help at 1.801.655.0800
Posted on Jul 08, 2010
How do you remove the thermostat from a 93 Polaris trail boss 350L 4x4
DOWNLOAD POLARIS TRAIL BOSS REPAIR MANUAL
trailboss-manual.blogspot.com/
Nov 5, 2014 - 4x4 free printable 1989 polaris trail boss 350 2x4 parts 03 polaris 350trail ... engine diagram trail boss 350 4 stroke diagram how to test the thermostat ... apolaris trail boss 1994 350 shop manual for 1993 polaris 4x4 trail boss ... boss 350oil pump repair manual for polaris trail boss 1987 removing jets in ...
Sep 25, 2015 | ATVs
2003 polaris 330 won't stay running with lights on
charge system fault
could be the charger ( alternator) voltage regulator or loose wires
indicates not enough power to run the ignition system when the head light is turned on
Nov 25, 2017 | Polaris ATV
Four wheeler wont start. it just clicks
if the 4-wheeler is just clicking when you try and start -- this is a good indicator that the voltage is not high enough to activate the starter,, and the sound that you hear is the solenoid clicking.
try and jump the four wheeler battery with a car battery,, this should give it the power it needs to turn over. as soon as you have the ATV running - ride it around for awhile and let it run and charge the battery, there is also a chance that the battery is going bad and it may be time to buy a new one,, also make sure the generator on the ATV is charging the battery at a voltage of 13.6 to 14.4 volts DC. IF jumping the battery still does not start the machine and it still just 'clicks',, then the solenoid itself could be at fault -- replace it and then try and start..
(( use a bench charger to fully charge the battery and re-install into the ATV and you should be back on the trail in no time at all )).
c...
Jan 26, 2011 | Polaris ATV
No spark at plug on 99 polaris 250 trailblazer
i bought a 92 polaris trail blazer im very confused cus it has no battery and no battery leads going anywere and it has a back up pull start but its not geting any spark at all what should i do im not very good with quads?
Oct 07, 2009 | Polaris ATV
Hello, We have a 1995 Polaris Trail Blazer 250
check your adjustement on your linkage
Sep 27, 2009 | Polaris ATV
Stalls when going up hills.
sounds like a weak fuel pump, not enough power to draw fuel under high pressure
Sep 15, 2009 | 2000 Cadillac DeVille
Disney princess dvd player will not play any dvd!
We had the same issue. Try clicking <play>1234<play> and it should unlockk the dvd in the machine. Seems to work on my daughters. It's a parental control of come sort. HTH.
Jan 17, 2009 | Disney Princess DVD Player
Polaris Trail Princess Logo
168 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
