Question about Fire Magic FireMagic Grill
How to shield wood cabinet from heat - Fire Magic FireMagic Grill
    Champion:
  • 274 Answers
You should not have flammable materials near the grill to begin with, but if you do. You will have to have a metal insert made for the grill to sit in.
Posted on Jul 12, 2010
Acoustic b600h
Relay?? I've never seen a guitar or bass amp with "speaker protection relays"...usually they're either on or off. Check the simple stuff 1st...is speaker cable from head to cabinet and/or the input cable from bass to the amp good? Check the "Direct Out" for a line level signal (must be connected to a PA or other amplifier) as this is your preamp out signal. Also, plug a shielded cable from "Effects Send" to "Effects Return"...this will verify "effects" loop issues if any. Lastly, vibration test...use a clenched fist across the top, sides and bottom of wood cabinet to lightly "jar" the internal circuits. If it starts working even for an instant, I would suspect intermittent connection inside.
Jul 30, 2014 | Acoustic B600h 600W Bass Head And B115neo...
What are the different types of cabinet doors?
wikipedia provides a good explanation, quoted below:
Frames
. In the U.S. solid wood frame and panel construction, using either mortise and tenon or cope and stick jointed frames, is traditional, with maple, cherry, oak, birch, and hickory among the most commonly used species. Mortise-and-tenon frames, with their greater strength and permanence, are more costly to produce and less commonly used as compared to cope-and-stick frames. As an alternative, miter joint frames, which may be identifiable by face-surface relief that follows continuously around the frame, have become popular. Miter-jointed frames typically employ embedded metal fasteners to secure frames elements (stiles and rails) cut at a 45 angle. Captured within frames, panels may be either solid or veneered engineered wood (either particle board or medium density fiberboard). Laminates, including those designed to resemble hardwood, can typically be identified by a more rounded appearance associated with the minimum bending radii necessarily entailed by the manufacturing process of applying laminate to an underlying substrate. By comparison, solid surfaces, and solid hardwoods in particular, can be milled with more sharply defined corners, edges, or grooves on either a panel or frame.
  • Panels. Panels used in frame-and-panel kitchen cabinet doors may be fashioned either of solid wood or covered by paint, veneer, or laminate in which case they are fashioned of engineered wood. The panels are typically not fastened with glue or nails but rather "float" within the frame to accommodate seasonal expansion or contraction of the wood frame.
  • Solid-door construction. Doors may be fabricated of solid material, either engineered wood (particle board or medium-density fiberboard, but not typically plywood) or solid wood. Engineered wood panels may either be used as slabs or may be shaped to resemble frame-and-panel construction. In either case, engineered wood panels are generally painted, veneered, or laminated. Solid wood panels are typically formed of multiple boards of the selected wood species, jointed together using glue and may either be painted or finished. Solid wood construction offers the possibility of refinishing in case of damage or wear.
  • Decorative panels. Cabinet doors panels can be used decoratively on cabinet sides, where exposed, for a more finished appearance.
  • Glass door construction options. Doors may have glass windows constructed of muntins and mullions holding glass panels (as in exterior windows). Other designs either mimic the divided-light look of muntins and mullions with overlays, or may dispense with them altogether. Cabinets using glass doors sometimes use glass shelves and interior lighting from the top of a cabinet. A glass shelf allows light to reach throughout a cabinet. For a special display effect, the interior rear of a cabinet may be covered with a mirrors to further distribute light.
Jan 30, 2013 | Hardware & Accessories
I was thinking of buying a cherry wood china cabinet. Is it a good idea?
China cabinets come in all types of styles and woods. Cherry wood is one of my favorites but you need to know how to take care of it so that it lasts and looks good. Here's a good article with tips and info http://www.kwintessential.co.uk/articles/china/cherry-wood-china-cabinet/1953
Aug 13, 2012 | Furniture
What are china cabinets made from?
China cabinets are made from wood. But you can choose whether you want unfinished (which is usually cheaper), stained, painted or antique woods. Antique wood china cabinets can cost a fortune depending on their history. So figure out your budget and go from there.
Hello< My dryer is spinning no
The problem when the dryer runs but doesn't heat is usually caused by a failed high-limit thermostat and a blown thermal cut-off both located on the heater housing. Verify this by bypassing both parts for troubleshooting purposes then running the dryer.
Disconnect power then remove the screws attaching the bottom front panel to the bottom flange of the cabinet. Slide the panel down and off the cabinet to access the heater housing.
Remove the hex-head screw from the heater shield and remove the shield.
Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards. Let us know should you need further advice.
Jan 11, 2011 | Kenmore Dryers
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
MOISTURE AND HEAT ESCAPE FROM DOOR SIDES CAUSING PROBLEMS WITH ADJOINING CABINET DOORS. WHAT IS CAUSING THE CONDENSATION / MOISYURE LEAK?
Unfortunately, dishwasher generate a lot of heat and water vapor. Some manufactures are now including a pressure sensitive mylar / aluminum strip to be attached above the door under the counter to prevent water vapor and or heat damage to wood or composition wood counter tops. However if water vapor is seeping out from the side of the door and causing damage to the adjacent cabinets woodwaork, the dishwasher door gasket may be faulty. Since this might be the problem, it would appear that your dishwasher is used a lot or getting old. New gasket is about $20. If the door closes and there appears to be a lot of play in the closed door,the latch may be in need of adjusting if possible. That is, even thought closed and operational, the seal is not tight and the dishwasher is running without having a tight seal on the sides. If you have a stone counter top, any water vapor / heat escaping from the top would not be apparent since stone is not damaged by the heat or water vapor, but the adjacent wood cabinets are.
Jan 15, 2010 | Frigidaire Dishwashers
Can't get the top bolt of alternator off on a 1999 jeep wrangler. what can i do?
a little heat with a propane torch does wonders use some thing for shielding anything you don't want burned,hardy plank[a cement siding board] scrap works good .if not wood or an old can.
heat the aluminum around bolt.
Nov 08, 2009 | 1999 Jeep Wrangler
We are having a wood burning stove installed near a wall in dinning room.no fire place.will we need a heat shied so wall will not get damaged or cracked? Installer will follow manufactures instructions...
Nothing wrong with a little added security.
Go with the extra heat shield.
Keep in mind this heat shield can be decorative too!
You will sleep better at night knowing there is little change heat build up will occur on that wall.
Oct 04, 2009 | Dacor 36quot; Internal Blower Wall Mount...
Fire Magic FireMagic Grill Logo
57 people viewed this question
Top Fire Magic Grilling Experts
paulcarew
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
