Question about Scotts Company Hand Held Spreader By Scotts 71133 ()
I have a hand held scotts spreader and i don't know which setting to put it on.
  • 279 Answers
The setting should be stated on the bag of whatever you are spreading. Use that setting...Good luck...Lee
Posted on Jul 05, 2010
What setting is used to apply 1/4 lb per 100 sq ft?
BigVin, normally the bag of seed tell what setting to put spreader on for its proper application, If not try it on #4 setting, it all depend on how fast you wind and walk with a hand spreader. Good Luck.
Apr 04, 2016 | Scotts 71030 Easy Hand-held...
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Mar 23, 2016 | Scotts Garden
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
I would like an instruction manual for a Scotts hand held spreader #71030. Thanks Ray.+
Call Scotts at 877-465-5160, and we'll be happy to send one to you!
Hilary @Scotts
Sep 21, 2011 | Scotts Company 126006 Scotts Easy Hand...
We have a Scotts Easy Green Lawn Spreader..(Probably have had it for almost 10 years...don't know how to tell what model, but the adjustment lever and knob are on the back. The single push handle is...
Call Scotts at 877-465-5160, and we will be more than happy to send the manual to you! Also, if you are using Scotts products, then the spreader settings are listed on the back of the bags.
Hilary @ Scotts
Aug 15, 2011 | Garden
I have lost my instructions for my hand held spreader. The numbers on the side that control the outlet of whatever is in the spreader--do these indicate the number of pounds per 100 sq. ft?
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
  • For fine grass seed (blue, rye, fescue) use setting 1
  • For coarser seed (tall fescue) use setting 2
  • For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
  • For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
  • For pelletized fertilizer and ice melt products use setting 5
Hilary @Scotts
May 16, 2011 | Scotts 71133 Handgreen II Hand Held...
What setting should this scotts hand spreader be on for hulled bermuda grass
A reasonable spreader setting for a hulled Bermuda seed would be a setting of a 2.
Hilary @ Scotts
May 13, 2011 | Scotts 71133 Handgreen II Hand Held...
Need to know the setting to put out Stagreen's crabex crabgrass preventer
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Feb 21, 2011 | Scotts Company Scotts Lawns Edgeguard...
I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Feb 15, 2010 | Scotts Company Scotts& Accugreeen 3000...
Scotts Company Hand Held Spreader By Scotts 71133 () Logo
242 people viewed this question
Top Scotts Company Garden Experts
john h
lnbn1975
jhnolson
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
