Question about Kicker ZX300.1 Car Audio Amplifier
My amp goes into protection mode once i turn up the volume of the music. I even turned the gain down low and once it gets to a certain level it still turns turns off into protection mode. My capacitor also recently started reading higher than normal voltage from the battery. Could the battery be the cause of the problem?
  • 4 Answers
What kind of subs u got
Posted on Jul 06, 2010
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Tip
My amp keeps TURNING off and on.
If it just started, you have an equipment or wiring problem. Check the wires first, that's easy. Otherwise, the amp may be bad, check the warranty if its new. Maybe you can get a replacement.
If it's always happened, some cars have an factory amp for the rear factory speakers hidden in the wiring. Sometimes between body panels. If you didn't bypass that, you're more than likely blowing out the new amp with too much power causing it to shut itself down. (protected mode or keep blowing fuses) Could be a blown speaker, bad ground, internal damage, RCA cable problem, the list goes on and on. Find out the preoutput voltage of your headunit and set the gain to what that is and nothing else LEAVE IT THERE, the gain isnt a volume knob for your amp its to get the amp and the radio on the same page (i.e. radios at 50% volume and so is the amp) if you turn it down too low that will make the amp very sensitive to volume adjustments and your amp will be at 100% while the raidos at like 50 or 75% and once you go past the 50 or 75 on the radio the amps going to keep trying to play higher even though its already maxing out which is going to cause it to clip and cause distortion untill it goes into protect mode. Hope this was helpfull to some one
on May 12, 2010 | Car Audio & Video
So i have installed my amp, epicenter, all wiring is done, hace great ground.. But once i turn my car on to sound check everything starts fine but after turning up the volume a bit.. My amo goes into...
It sounds like you have your gain to high. best way to solve this is by turning the gain way down to - or lowest number , then turn everything on and upto the volume you desire, then slowly up the gain. also avoid using bass boost, I agree it sounds great but it puts strain on the amp and shortens life in the amp. with the bass boost off, you can adjust others (not the gain) to get bass.
Hope this helps
Jan 26, 2013 | Car Audio & Video
When i turn my volume up to a certain point the power light on my amp will blink off and on and the subs will cut off...what could be some possible solutions? is the amp not suppose to be tuned up? it...
Sounds like you are showing too low of an impedance load to the amp. The E1200 is only stable as low as 2 ohms. If your subs are wired to show lower than a 2 ohm load then the amp will go into protection mode as the volume or gains are turned up
Dec 23, 2010 | Jl Audio E1200 Car Audio Amplifier
Amplifier shuts off or goes full blast
That a new one for me, it just goes full blast huh? I don't have an answer for that, but your amp can shut off because of a lot of reasons.
One you might not have enough power running to this amp. Check to make sure your amp gain is not turned all the way up, this is NOT the volume for the amp. It's to get your amp and the head unit on the same page (i.e. if the radios at 50% volume and so is the amp) if you turn it down too low that will make the amp very sensitive to volume adjustments, and your amp will be at 100% while the raidos at like 50 or 75%. And once you go past the 50 or 75 on the radio the amp, it's going to keep trying to play higher even though its already maxing out which is going to cause it to clip and cause distortion untill it goes into protect mode. Common mistake with a lot of people.
Two you might check all your wire connection to the amp. Three internal damage. The list can go on and on as you can see. RCAs might be damage or even your remote wire. Upgrading your alternater and battery can help.
Some people would even say to check your car factory amp (some times in the trunk or in between body panels) to see if it is bypassed. If it is not bypassed it could be a posability to shut down the other amp caused by to much power causing it to shut down. hope this was helpful
May 12, 2010 | AudioBahn A1500HCT Car Audio Amplifier
When I turn the volume up past 3 it starts this
I suspect you are going into protect mode which backs the gain way off to prevent over driving.
You MAY be trying to get too much volume out of it. Remember that the value of "3" on the volume means ALMOST nothing as you may have a hotter guitar. Some guitars with internal preamps EASILY overdrive the amps at low settings. Do not use excessive gain at the input.
If the amp is real low volume way below what is needed to play, then there may be a problem with the protection/compressor circuit.
Suggestion: Take your guitar to a music store and compare action on an IDENTICAL amp.
Feb 01, 2010 | Music
My subwoofers don't perform consistantly. Sometimes they work flawlessly, other times they make a loud thumping that is not coming from the music (but it does interfere with the music). To be more...
Try turning the gain, or output level down on the amp, if that doesnt solve the problem then check the aux wires and the remote wire for shorts...
Aug 06, 2009 | Car Audio & Video
Creative Zen
Most audio software these days offer either built-in or plugin functionality that will attempt to level the volume of your MP3 files so that you aren't turning the volume up to hear soft songs, then getting blasted by louder ones. So why is it that even after turning that option on, you sometimes notice a significant volume difference between some songs? What's worse is when you're listening to songs from the same album, and the volumes jump around abnormally after applying volume normalization.
The problem is that the vast majority of audio player programs use peak amplitude analysis to determine how "loud" a song is and normalize based on that, rather than doing a more comprehensive analysis of the frequencies that impact how loud the music actually sounds. But even those that do a more comprehensive analysis fail to consider songs within the context of the album they belong to.
Luckily, there's a great little utility called MP3 Gain that does lossless volume analysis and adjustment based on David Robinson's Replay Gain algorithm, as well as allowing for the volume of entire albums to be processed. MP3 Gain has been around for a number of years, and it doesn't appear that it is being actively developed anymore, but since MP3 technology hasn't changed much either that doesn't matter for our purposes.
So, how do you fix an entire library of music? Pretty easy, actually. MP3 Gain offers batch processing options that allow you to process an entire folder at once. But if you collect music albums, you'll want to do those separately. The reason is that MP3Gain offers two modes: Radio and Album. Radio analysis and gain adjustment will adjust all songs to the same maximum decibel level. Album mode analyzes all of the songs in an album, essentially considering them to be one entire song, then adjusts them all to a maximum decibel level, but maintains their relative volume.
Jun 21, 2008 | Creative Labs Zen Digital Media Player
Peavey Bass amp 115
HI Subicbay,
ADjust your Gain setting to limit just enough so the amp does not go into Protect mode. Turn your Gain all the way down, then crank up the bass from your system. GRadually turn up the gain until you trip on protect. Turn the gain back a notch and your set for no more protect.
Oct 27, 2007 | Jensen XA4150 Car Audio Amplifier
Amplifeir keeps turning off
HI K-****, Adjust your Gain setting to limit just enough so the amp does not go into Protect mode.
  1. Turn your Gain all the way down,
  2. then crank up the bass from your system.
  3. GRadually turn up the gain until you trip on protect.
  4. Turn the gain back a notch and your set for no more protect.
Oct 19, 2006 | Jensen JPA460 Car Audio Amplifier
Kicker ZX300.1 Car Audio Amplifier Logo
442 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
