Question about Music
The sustain pedal is permanently on!
I have a sx px 665 electric piano and the sustain pedal is on all the time! I`ve tried taking plug out of back of piano and putting it in again but makes no difference! We have an end of term show next week so we are somewhat panicking!!! Can anyone make any suggestions?
  • Music Master
  • 5,603 Answers
You MAY be trying to use a Roland pedal on an instrument that requires a different one.
The Roland have a normally closed contact where MOST others are normally open.
If you are using Roland equipment, then use of another brand OR a broken cable will cause this as will a shorted cable with other brands.
It looks like you MIGHT have a Technics given that number you posted. Not sure of which polarity pedal you require with that, So you need to test it.
Plug in a regular instrument cable and see if it sustains with nothing at other end. If it does, you need a normally closed one.
Posted on Jul 05, 2010
I have a Piano from Casio Named The PX830 BP.I also have a Sustain Pedal Model from Casio named the SP 33.Will connecting the SP 33 into the PX830 BP work?Please tell me if I have the wrong model.
Unfortunately, the SP33 pedal will not work with the PX-830BP. Casio lists that the SP33 will only work with the PX-150BK, PX-150WE, PX-160BK, PX-160GD, PX-350BK, PX-350WE, PX- 360, and PX-560 keyboards.
The PX-830 manual does not list the stand or the pedal unit as separate items if you need to replace them. The pedal unit has 3 pedals like a traditional piano. I wish that I had better news for you.
Feb 04, 2016 | Casio Music
HP 337. Why has sustain pedal begun only working intermittently?
i am not sure about your piano but i have a pedal for my guitar and over time it accumulated dust under the top part that had apparently made a bad connection to the contact. blow it out real good with an air compressor and that may fix it. it did for mine. hope this works.
Jan 08, 2016 | Music
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
May 18, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Fix
Replace the internal micro switch or just by a new pedal
May 08, 2013 | Casio SP3 Sustain Pedal
My casio privia px830 pedal doesn't sustain enough,
It could be that the electronics of the pedal are dirty, or that dirt has collected under it causing it to not depress all the way. Try taking it apart and cleaning it with a Q-tip and rubbing alcohol. Be very careful of any wires or delicate articles.
Dec 06, 2011 | Casio PX-830 BK Privia
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Fc4 sustain pedal is in "sustain" mode at all times -- it won't release the sustained notes. I tried plugging the pedal in (to a roland ep-9) before powering up and had the same problem.
Sorry, but the Yamaha pedal has the opposite sense (it is a normally open contact) than what is REQUIRED by Roland equipment. Roland requires a Normally Closed contact. Unfortunately, one is confused because the Roland jack for the sustain shorts itself to no sustain when you unplug a pedal. SOMETIMES one can open a pedal and with soldering iron change a wire to reverse the pedal sense IF the particular pedal has both contacts available.
Jun 16, 2011 | Yamaha FC4 Piano Style Sustain Pedal
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
Hello- my P95 sustain pedal does not work when plugged in but the sustain works when you disconnect the cord from the back of the keyborad
This is confusing... you say "the sustain works when you disconnect the cord"? How can that happen? and doesn't work when it is plugged in.
MOST sustain pedal problems are due to people using a different pedal than the keyboard is designed to use. It is very common that someone tries to use a Roland sustain pedal on a Yamaha and oof course it doesn't work because the Roland pedal is normally closed and Yamaha usually requires a normally open contact.
A FEW keyboards now check the state of the pedal input when power is first turned on and configure the pedal polarity accordingly. For these keyboards, make sure the pedal is plugged in before power is turned on.
Apr 02, 2011 | Yamaha P95 Digital Piano
What type of sustain pedal Roland EP-90 digital piano is using - open or closed at rest?
CLOSED is typical for Roland pianos when at rest. (open to sustain).
Note that the jack PROBABLY has a grounding contact so when no pedal is used/plugged in, the jack is shorted at the piano.
Sep 19, 2009 | Music
Music Logo
230 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
