Question about iRobot Roomba 550 Vacuum
Roomba goes in a circle moves about 5 inches and then turns in a circle again. It won't dock or go any farther than a few inches before turning in a circle again. The roomba has been cleaned inside and out. All hair and debri as been taken out of the wheels and brushes. i opened the case and cleared all the debri and i dusted the sensors in the front. Not sure what to do now.
SOURCE: Brushes are clean, but Roomba stops and says clean brushes
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Posted on Nov 20, 2008
jackiaria
  • 350 Answers
SOURCE: roomba keeps going around in circles
Dear Roomba Owner,
For solutions to your Roomba Vacuum Problems click on the following link @ http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/home.php?p_sid=gG54ERqj
jackiaria
01e9bc8.jpg This Will FixYa!
A Lot of iRobots' Home Vacuums Need a Software Upgrade!
Posted on Feb 19, 2009
SOURCE: roomba keeps saying clean brushes yet are clean!
Remove the Yellow connectors on the end of the brushes and clean around the pin well. If there is too much there, the roomba thinks there is something stuck and goes into clear mode (as if there is a chord stuck).
Posted on Feb 24, 2009
  • 61 Answers
SOURCE: no suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Posted on Jun 03, 2009
SOURCE: roomba won't pick up debris
I had this problem until I wiped the dirt sensor, which you will find under the rollers.
Posted on Jan 02, 2010
My iRobot Roomba 780 just won't start moving to do the cleaning. When I press the CLEAN button it moves back from the dock, turns 180?, and then moves forward about an inch and makes the uh-oh sound...
make sure all virtual wall lighthouses are turned off. Your Roomba may be getting a signal to not proceed if the lighthouses are turned ON and facing the Roomba
Feb 22, 2014 | Roomba 780 Robotic Vacuum
Stops
I had the same problem when I renovated my kitchen. With boxes of stuff everywhere it was impossible to use Roomba. When I tried to use it again a few months later, it would stop after only a few minutes work. I had to buy a new battery which cost in excess of $100. Its better to loan it to a friend to be used than to put it into storage.
Apr 30, 2013 | iRobot Roomba 530 Robotic Vacuum
Roomba starts out in a circle goes wider and wider then all at once goes in circles.
when it starts doing that hit the start button again then wait a few sec.
Jul 19, 2010 | iRobot Roomba 560 Robotic Vacuum
560 moves away from dock appears lost
hey gsaban
does it sing 9 beep when it stops ?
if it does, you are facing a known issue of bumper sensor fail.
See this page and other 9 beep threads on FixYa
have fun
Avi
Mar 12, 2010 | iRobot Roomba 560 Robotic Vacuum
Backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Jul 23, 2009 | iRobot Roomba 500 Series Virtual Wall...
Roomba going backwards
I had the same kind of problem with my model 400 today...after starting it and having it go in a circle for 30 seconds or so it would finally run into something and then back up a few inches, turn, then go forward a few inches, then back up a few inches, turn, then go forward a few inches, etc., etc.. I tried cleaning off the four pairs of sensors under the bumper and blowing out various things underneath (by mouth since I didn't have any canned compressed air). It didn't really help. It then occurred to me that I had a leaf blower! I put the Roomba upside down on the grass, put the leaf blower on high, and blew at it from all directions and up close. More dust came out than I thought would. It has been running normally now for the last 45 minutes.
Aug 11, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
My roomba starts going backwards
Apr 18, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
IRobot Roomba Discovery not moving across room.
Sep 26, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 550 Vacuum Logo
89 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
