Question about Omega Rear Drive Wheel Snapper Mowers
Snapper lawnmower will not start - sparkplug is good, air filter clean, no idea what is wrong
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 275 Answers
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the vertical intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Posted on Oct 08, 2010
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
On the Zero turn mower , how do you relieve the air in the pump lines after replacing a bad pump . Please advise.
How To Release Pressure From Fuel Lines - YouTube
? 0:51
www.youtube.com/watch?v=6oo9zlTMPOQ
Oct 15, 2009 - Uploaded by YeechBlitz
See a demonstration on how to release the pressure from fuellines of a 1997-2000 ... in the tank, but do not let the air out, so pressure can build up in there. ... Diesels is where you want to be extra careful, the injector pump to ...
5900748 Snapper Zero Turn Mower - Hammerwall
www.hammerwall.com/.../Snapper/.../5900748/Snapper%20Zero%20Tur...
Back To Snapper Tractors-Riding-Lawnmowers Model: 5900748 Snapper Zero ......Reinstall each mower blade with the air lifts pointing up towards the mower deck ... The fuel filter is located in the fuel line betweenthe fuel tank and fuel pump . .....TROUBLESHOOTINGTHE RIDER PROBLEM CAUSE REMEDY Enginewill ...
Sep 25, 2015 | Briggs & Stratton Snapper 5900748 355Z...
725 ex briggs and stratton
Might be the carburetor or air filter dirty. Need right amount of air to mix with fuel at the right time.
To service these best to check this video out. Yours may not be the same exact model but gives an idea.
REPAIR BRIGGS STRATTON LAWNMOWER TUNE UP CARBURETOR CLEAN
Sep 01, 2014 | Snapper Garden
My snapper hi-vac niwer us hard to start. I can't pull hard enough to get it to start. It uses straight gas, not mixed with oil.
If you are having problems starting your mower you shouldcheck 3 things, air, fuel and spark.
Fuel: check to make sure you are full of good quality fuel, try to start theengine several times then take out the spark plug and it should look wet. If its not wet then you aren't getting fuel into the engine.
Air: remove and clean the air filter with clean gasoline if its made offoam. If its made of paper then you should buy a new one from a localauto parts or hardware store.
Spark: disconnect the spark plug wire from the spark plug and hold thewire close to the engine block. Try to start the engine and watch for aspark to jump between the end of the wire and the engine block. If itdoesn't then either the wire is bad or the ignition coil is bad.
Jun 09, 2011 | Snapper 217020b Lawn Mower Mowers...
Sears lawnmower model 917387272
Unless someone has modified it, there is no fuel filter. The fuel tank is coupled direct to the carburetor by a short piece of hose.
Your running problem is most likely due to (dirt and/or moisture) contaminated fuel in the float bowl. You will need to remove the float bowl and clean it out and clean the carburetor main jet at the same time
Oct 31, 2009 | Craftsman Garden
Lawnmower starts but won't continue to run
if you are getting no fuel to the plug you either have a stuck float, plugged fuel line or filter. does the gas reach the carb bowl? does the mower have a fuel pump? if so the diaphram might be bad.
Jun 30, 2009 | Garden
My Toro revs up and down and is shutting down. New sparkplug, new air filter
Two things to check: 1) A restricted fuel filter would cause this problem. 2) Debris in the carburetor. My lawnmower would start, rev a little bit, then die. I could keep it going with the primer pump. The problem was the main jet in the carb was obstructed. The solution was easy since there was a plug on the bottom of the carb which provided access to the main jet. I removed the plug then removed the jet with a 6mm wrench. I cleaned it with carb cleaner and re-assembled. Ran great after that.
Good luck,
Techjoel
Jun 05, 2009 | Garden
Lawnmower starts but won't run-replaced airfilter and plug cleaned carb
If it is starting and not continuing to run it still sounds as though something is blocking the fuel flow. If the carb has been cleaned out, literally torn down and the needles cleaned so that no small debris is clogging them, check the fuel tank and lines for anything that could be restricting the flow to the engine. Remember that it's recommended that you replace the fuel line (cheap fix) when you dismantle the carb. Removing the line breaks off small pieces of the rubber in a worn line, which can re-block a freshly cleaned carb.
May 12, 2009 | Garden
I have a lawnmower with a BSA 3.5 engine that I cannot start, the problem seems to be no spark at the spark plug. As I have never worked on a lawnmower I have no idea what generates the spark on...
Test for spark by placing a screwdriver into the spark plug wire and holding it close to a bolt on the engine. should see a spark (blue). If not, problem is likely the armature (coil). The coil is located under the engine shroud and held in place by two bolts. If you replace this part, (normally $30 to $40) you must ensure a proper air gap. Auto parts stores have inexpensive repair manuals to help.
Lee
Cherokee Small Engines
Apr 21, 2009 | Garden
Lawnmower keeps cutting out ,have cleaned sparkplug but still cut
Try takeing the air filter off,shake well,and reinstall,if still stalling remove air filter and leave off and see if it still stalls?? Let me know and please rate. thanks
Mar 17, 2009 | Garden
Omega Rear Drive Wheel Snapper Mowers Logo
924 people viewed this question
Top Omega Garden Experts
cwradio73
Rodney Carroll
Level 1 Expert
randy yarpos
randy yarpos
Are you an Omega Garden Expert? Answer questions, earn points and help others
