Question about Dyson Ball DC24 Bagless Upright Vacuum
Brush stopped spinning
I have a Dyson DC 24 and the brush stopped spinning because it was clogged. I removed all of the hair etc. and replaced the brush, but it still is not spinning. Any suggestions?
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Posted on Sep 08, 2010
Trip switch wont reset on brush head
Posted on Sep 12, 2010
I have a dyson DC 39 animal and my head does not spin fast. help
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc39
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 17, 2016 | Dyson Vacuums
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Why does my Dyson Dc-39 vacuum have good suction, but the beater bar barley turns?
    The beater bar may be clogged with pet hair and other debris. You may have to do some disassembly to get everything working again.
    Dec 18, 2014 | Dyson DC39 Animal Canister Vacuum
    How can I get the brush on my new Dyson vacuum DC-46 to turn?
    You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    https://www.thinkcrucial.com/search?type=product&q=dyson
    Ava B.
    Jun 01, 2014 | Vacuums
    Brush bar won't spin. Both filters have been cleaned ,all hoses checked for blockages,brush bar removed for cleaning
    Hi there, it's Jack at Dyson.
    DC25 doesn't use a conventional, user-replaceable belt. Instead it it uses a belt engineered to last the lifetime of the vacuum in normal use, protected by a sensor which shuts off the brush bar if something jams it.
    Normally, checking the cleaner head for obstructions and removing any threads or hair from the brush bar and endcap will allow you to reset your machine:
    However if you've already followed each of the steps shown in our video guide without success, you may need a replacement cleaner head or a repair of your machine. If you can contact us directly we should be able to arrange this for you, and can also confirm if this is covered under your Dyson warranty.
    When you have your DC25 easily to hand, please get in touch with the Dyson Customer Helpline so we can help determine if a repair or replacement part is needed. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    We'll look forward to speaking with you.
    Apr 06, 2014 | Dyson Dc 25 Animal
    Dyson dc 24 brush works intermittently
    Broken wires in the side of the machine
    Dec 27, 2013 | Dyson Vacuums
    Hi Chris, it's Jack at Dyson.
    DC24's brush bar is designed to shut itself off for protection if something jams it. Please follow the steps shown in the video attached to remove any threads or hair from the brush bar and end cap, and to check the cleaner head for any obstructions. Once you've done this you should be able to reset the machine.
    If you'd like further advice from our experts after you've given this a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA). If a repair or a replacement part is needed, we'll be happy to confirm if this is covered under your machine's 5-year warranty.
    You can also find help and support by visiting www.dyson.com and clicking 'Support'.
    Brush bar is not spinning
    Common causes of brush roller failure are belt breakage and clogging. If this is a Dyson animal vacuum, you may find the brush roller is so clogged with hair that it cannot rotate. The solution is to remove the brush roller and clean it thoroughly, particularly inside the end caps where hair accumulates. It is unlikely that an entire animal was ingested.
    Nov 20, 2013 | Dyson DC28 Animal Vacuum
    Dyson DC-14 beater brush not turning
    Ava B.
    Oct 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson DC 14 Animal - The carpet brush does not turn. I cleaned thoroughly per the instructions but the brush does not turn. I tried moving the carpet/bare floors switch with the same results - carpet...
    The brush will only spin when the machine is reclined. Not when the machine is stood upright.
    If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
    Jan 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson Ball DC24 Bagless Upright Vacuum Logo
    4,747 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
