Question about HP Pavilion a350n PC Desktop
My hp pavilion pc doesn't respond to video
My hp pavilion f70 pc doesn't respond to video maximization from the normal or minimum view online ro window media
    Novelist:
  • 177 Answers
That is because you need to download any codecs or ad-ons for your browser. (Flash Player updates, java, etc...)
The content is handled throught the server online, not on your hard disc or local device, therefore, it's not a hardware issue, but rather the software, or in your case, lack of.
when you are online and streaming video on web pages, you will see a notification bar above your browser window (below the toolbars usually) that prompts you to download or update a plugin, codec, or execute a program, app, or add-on.
Posted on Jul 06, 2010
Hp pavilion f70 monitor turns white. when i turn it off and back on with the monitor power buttom the video returns but goes off again after a few munutes.
Verify that it's the monitor and not the computer by hooking another monitor to the computer and observing the results. If it's your Hp f70 that is the problem, then something in it is going out, like the inverter or perhaps a loose connection. If you don't want to open the monitor and have a look-see for yourself you can always take it to a shop to have it checked out.
Mar 13, 2011 | HP Pavilion F70 17" Flat Panel LCD Monitor
I need an internal pin out diagram for a 4 Pin connector to connect power supply to a hp pavillion f70 monitor. I do have a power supply with same specs but it has a normal plug with outer as +ve and Inner...
12 VDC , 4.16 A (4,16 A) Frequency: 50/60 Hz Power Consumption: less than 36 W in operating mode.
I think the other two pins are not used. It just requires the 12 Volts DC. +ve and -ve, positive and negative, respectively.
Feb 10, 2011 | HP Pavilion F70 17" Flat Panel LCD Monitor
My HP Pavilion dv7-3080us is having a keyboard problem. Pressing F8, or Backspace does nothing. The problem occured soon after purchasing the computer and simultaneously for both keys. The keys doesn't...
The keyboard got busted. If it has warranty send it back else you can shop for a replacement keyboard online. They are easy to install and doesn't require much work.
Jan 17, 2011 | HP Pavilion dv7-1130us laptop
Where can I buy a lower price HP PAVILION DV8000
It's much better to buy the battery from the manufacturer's website. The transaction is a lot safer and reliable. Take there are two categories of battery the ORIGINAL and REPLACEMENT. Normally the highe mAh capacity has the longer battery life. The price of REPLACEMENT batteries are much lower than the ORIGINAL batteries.
You can view the product on this site:
http://www.shopping.hp.com/webapp/shopping/product_detail.do?product_code=EF419A
Thanks.Cheers!
Apr 21, 2010 | HP Pavilion dv1000 Notebook
How do you disassemble the hp pavilion f70 monitor? The monitor does not light up and I think it's the backlight.
plumldk1, Watch some video clips of "LCD monitor disassembly" at youtube. Yes, parting the rear cover from the front plastic bezel is the hardest thing to do!!!! Also visit www.ccl-la.com/badcaps.htm. You might see some tricks to help get the thing apart. Are you positively certain that it's the "backlight" and not the "electronic ballast" that has failed? Will you find any swollen electrolytic filter capacitors on the SMPS board? 12fixlouie
Jan 17, 2010 | HP Pavilion F70 17" Flat Panel LCD Monitor
My hp pavilion f70 flat panel lcd monitor comes on and works fine with a beautiful picture...for about 1/3 of a second. then it goes blank. any ideas how i can fix this or what might be wrong?
Hi:
The symptoms you describe, pretty much diagnose a failed High Voltage power supply board problem in the monitor. This is usually cost prohibitive to repair, as LCD monitor prices have dropped a bit, so your monitor is beyond economical repair.
Nov 30, 2009 | HP Pavilion F70 17" Flat Panel LCD Monitor
Can't view videos
If its for on-line viewing then you need to install the latest Adobe Flash Player so you can view the video.
Get Adobe Flash here >>>>>>>
http://get.adobe.com/flashplayer/
Once installed restart the PC and you should now be able to view online vids
If it just to watch DVD movies then you will need the latest codecs installed >>>>>>>
Get K-Lite codec pack here >>>>>>
http://www.codecguide.com/download_kl.htm
Good luck
Jun 12, 2009 | HP Pavilion a1610n PC Desktop
Install vista to hp pavilion dv5 laptop
Make sure the laptop meets or exceeds the resources needed to run Vista. For all versions of Vista, at least a 1 ghz processor or higher, and 20 to 25 GB of free space on the hard drive. Memory: 512 for Vista Home basic, 1GB or higher for Vista Home Premium, Business, or Ultimate. The video in the laptop must be 16 mb or higher. You MUST meet the minimum requirements or the install and startup will fail.
Mar 24, 2009 | Computers & Internet
Viewing full screen video clips
what is the website, or you can't watch all the video online in full screen, if you use themes for your computer for example crytal clear which turn xp into vista it might cause this problems, unistall it.
Nov 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion a350n PC Desktop Logo
50 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
