Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
La Cie (500 GB) icon not showing up on desktop
Already tried restarting computer, logging off and back on, turning La Cie off then on, searching for icon elsewhere in computer - no luck. not the first time to happen but usually would show up after either restarting computer or turning things off and back on. thanks for the help! kurt
    President:
  • 2,291 Answers
Check in disk management if it is showing the drive, go for troubleshooting, install some hard disk tool to fix errors for it, run registry cleaner to fix rigtry key for folder icons, reginout may help u
Posted on Aug 19, 2010
  • 1,472 Answers
Kcrosbie
If you are having trouble with the drive it is possible that the USB controller on the drive failed but the drive its self should be fine.
I would try the drive on another computer to see if it detects properly. Sometimes if the drive gets stopped improperly this can cause detection propblems but connecting it to another computer will force a scan of the drive that will repair any corrupted files that may be on the drive. Also check to see if the drive shows in disk management. The links below will show you how to check this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If the drive does not show up in disk management and the drive is not in warranty I would recommend opening the drive and connecting it directly to your computer to access the data.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Jul 05, 2010
How do I transfer from my la cie to my computer
Remove the USB module from the LaCie Write Card and plug it into a free USB port on your computer. Your computer should assign a new drive letter to the USB module (such as D: or higher letter). In Windows use Windows Explorer (on a Mac use File Manager) and you will be able to copy files from your LaCie USB module to your computer.
https://www.lacie.com/download/datasheet/DS_WriteCard.pdf
Sep 25, 2014 | LaCie La Cie 131057 Write Card Flash Drive...
My external La Cie 500Gig HDD has worked well for 3 years or more. Now when I connect it (via USB as aI have always done) ..The following happens: 1 I see the drive usually but not always under "My...
your drive has failed at either the power supply level or internal hard drive level.
First, please verify your power supply. When plugged into the power outlet, it should be silent. A defective power supply will hiss or have a high pitch noise to it. If it is defective, replace it and check if the issue is resolved.
If the power supply is silent, one or both of the internal hard drive is failing. If no data is needed, you can either replace the defective one which you will have to isolate by connecting the internal hard drives to a computer or with another enclosure and running a block scan software like hdTune which is free to download. The other option would be to scavenge the healthy drive and use it in another enclosure or inside the computer directly.
If you need the data and the problem was not the power supply, you will need to contact a data recovery center.
Regards,
Jan 07, 2011 | LaCie Big Disk 500 GB Hard Drive
250 GB La Cie desktop Quadra drive will not mount and makes a soft clicking noise; does not show up on System viewer, only as 'unknown device' Mac Pro OS X 10.5.6 Have tried to swap out firewire cables,...
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Sep 20, 2010 | LaCie (300770) 250 GB Hard Drive
I have an old La Cie 160gb (maybe 5 years old?) - do you know the specs? rpm, for instance? I need something with 7200. This old one must be 5400, right?
Lacie drives have a 5400 RPM on there 160GB line nothing really changed until 500 GB to 1tB at 7200 RPM.
so the answer is 5400 RPM
Hope this helps please do rate and leave feedback.
Apr 29, 2010 | LaCie (300740) 160 GB Hard Drive
Mac won't acknowledge Mybook!
try restarting your computer with the mybook plugged into it. also, leave it plugged in for a while and check back to see if it shows up on the desktop. I had a similar problem with my hard drive too, and this seemed to work.
Jul 21, 2009 | Western Digital My Book Home Edition 500...
Blu light flashing
This is most probably a faulty power cable, a common fault on La Cie apparently. Another cable got my disk working fine!
Nov 12, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Maxtor One Touch 4 500 GB External Hard Drive (Windows XP (SP2) - I have an issue with my harddrive, where when I plug it into the USB, initially the power light comes on & beeps but it is not showing...
Had same problem. I shut down computer and restarted and Maxtor was installed and had desktop icon and everything worked then. I then backed up with no problems.
Apr 14, 2008 | Computers & Internet
La Cie External Hard Drive 160 gig
A clicking noise from a harddrive is defenenly NOT a good thing. It usually means that the harddrive is going bad.
Nov 17, 2007 | Computers & Internet
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
150 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
