Question about Panasonic CT-27D11 27" TV
Panasonic CT-27D12D turning off on it's own
The TV is turning off on it's own. Neither the remote or the power button helps, the only way to get the picture back is to bang on the area where the Action and TVVideo buttons are. Then few seconds later it can disappear again, only fix again is to hit the TV, but then it works for a week or two without issues. I was thinking that this is due to a faulty power relay, but I am not 100% sure, and don't know how to fix it.
Any help is very appreciated, I am close to throwing the TV out. And of course all this started a month after our extended warranty ended.
  • nopliiz Apr 22, 2008
    Thanks Julian, I'll try this on the weekend.
  • marlonbd Apr 21, 2009
    I have the same problem and when I hit the on/off action or the general button areas, it restarts , sometimes for a short time or longer periods
  • 975 Answers
It sounds like a DRY SOLDER somewherein the PC board where the POWER SUPPLY located , I suggest , if your HANDY with this procedure, Im sure you can get it fix , FIRST lets remove the back cover to get inside the TV ( if TV was recently turn ON , you need to unplug it and wait till the next day to do procedure , cause the picture tube acts like a BIG capacitor reserving electricity,cause we goona need to remove that big RED round rubber plug to the tube ) . to make it short , you need to remove the PC BOARD and look for any dry solder , and resolder it ,that will take care of this problem
Posted on Apr 18, 2008
NEED A PART NO. FOR ZENER DIODE D830
It is an easy to get component, All zener diodes will have a breakdown vltage, and it will be marked on it body. Read it, and buy a new one from any electronic spare part selling shops.
May 12, 2012 | Panasonic CT-36D31 36" TV
Universal remote code for a panasonic ct-27g14a
Two things you can do:
GOOGLE THE NUMBER OR MODEL OF THE REMOTE AND LOOK FOR THE INSTRUCTIONS FOR PROGRAMMING IT.
GOOGLE THE MODEL NUMBER ON THE REAR OF THE TV WITH THE WORD REMOTE AFTER IT FOR A DIRECT REPLACEMENT.
LET ME KNOW IF YOU NEED HELP
Mar 15, 2012 | Panasonic CT-27G14 27" TV
I have a problem with my Panasonic CT-27SX12 27"
On remote you must push the TV button first then the on button to activate or deactivate the TV. Channel or volume on the TV does not need to select anything on remotes.
Nov 18, 2010 | Panasonic CT-27SX12 27" TV
I moved tv now it want go past channel 13
No problem. Go into menu to channel or tuner setup.. When it was unplugged the tuner reset to air and needs to be changed to cable and then auto program the channels..
Oct 17, 2010 | Panasonic CT-27D12D 27" TV
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
How do you reset the parental password
I have a Panasonic CT-27D12D with the exact same symptoms with the exception that my LOCK SET was OFF. I call the Panasonic technical servicxe and they had me to press simultaneously the "POWER" and "ACTION" buttons on the TV for about 5 seconds. A Self Check screen appear with OK's beside a list of functons checked. Next I was told to turn OFF the TV for about 5 seconds then turn it back ON and see if I could enter my Lock code. It worked. The procedure apparently reset everything.
Jun 23, 2008 | RCA 27F530T 27" TV
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
CHANGE CHANNEL
TRY manually if it does not help your problem 1 remote contacts. 2 remote. 3 problem in tuner 4 problem in system control circuit relating to tuner.
Sep 26, 2007 | Televison & Video
Panasonic CT-27D11 27" TV Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
