Question about Dell Dimension 2400 PC Desktop
Tried to upgrade dell dimension 2400 256 memory cards.
I have two dell dimension 2400's. I tried to replace the two 256 memory cards with 2 512's to upgrade the memory in each computer. They failed to boot up properly. So, I took them all back out and put back in the original 256 cards. One computer boots up correctly and the monitor can read it. The other computer boots up with all lights lighting up green correctly/no beeps on start up, but the same monitor does not read it.
Any advice?
Thanks.
  • Dell Master
  • 1,606 Answers
If you do not see any activity and no beeps then the memory module could either be not seated right or was damaged by static. Or you could have knocked something loose (nah that never happens ;-])
To boot and generate a beep code the motherboard needs to see the first 64k of ram. So you can be sure that the problem or part of it will be the #1 memory module. So take it out and reseat it, and then try again. If nothing then swap it's position with the other module and see if that works.
Look around the case and then reseat any connectors. You may need to pull them off and then push them back on to be sure. The heat cycles from the boards running can cause them to work loose and then they just need a bump or a brush to disconnect. On some cases you can do the same just by picking it up by the corners. The case twists and pop.
If nothing is out and it still won;t work your other option is to start swapping parts into the other case to verify they are working.
Posted on Jul 05, 2010
Testimonial: "Thank you. I tried a number of things you mentioned already, but will try again. Thanks for offering so many solutions."
  • Dave King
    Dave King Jul 06, 2010
    If none of these get it sorted out then reply here again ( I get message that way) and we can try a few other things. Unless you killed something by a static discharge this is an annoying type of problem, shouldn;t be serious.
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
I have a dell Dimension 8250 and replaced the memory cards with a higher memory. I got a memory error beep code so I replaced the original. I'm still getting the beep code. Any ideas? I was careful...
Please check the following link for complete information on Dimension 8250
http://support.dell.com/support/edocs/systems/dim8250/
Check the technical specification section to see if u bought the correct memory type for this computer to upgrade..if yes then proceed to the adding and replacing parts section to check for the instructions on adding memory.
Jun 27, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
Memory upgrade problem
That does not sound like a problem with a memory upgrade. try to unistall McAfee and reinstall. The memory change may have threw McAfee off. Make sure that the ram is also in the right bus. Buses are color coded and the 2 ram stick have to go into the same bus. this can cause problems
Jan 15, 2009 | Dell Dimension 3100 PC Desktop
Dell dimension 4550
Dell has a habit of using proprietary memory in their machines, if it isn't proprietary you can near guarantee that cheaper memory sticks will not be recognised.
Play safe and use the memory configurators at crucial.com and newegg.com
I bought two DDR2 1gig sticks at crucial yesterday for $50.00 for both with free shipping.
Jul 24, 2008 | Kingston 1GB PC2700 DDR DIMM Memory
Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
May 14, 2008 | Computers & Internet
Dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 2400 PC Desktop Logo
113 people viewed this question
Alun Cox
