Question about Hayward Pool & Spa
Our Hayward gas heater keeps giving us a H5 error code and then shuts off. What does this mean?
  • 760 Answers
Could the Error code be HS? That is high temperature limit. Perhaps you' don't have enough flow, allowing the heater to heat the water to a temperature higher, than the thermostat setting. Make sure your bypass valve is closed, allowing full flow through the heater. Check your filter pressure differential , and skimmer baskets.
You didn't give your model number, and there are many models. You can go the Hayward website below and select your exact model number and download the manual. The manual will explain each error code.
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
We a "service" message on our Hayward gas heater h250fnd also error message HS or H5
the code is HS. it means that the maximum allowed temperature has been reached too fast. there are a few situations that may cause this. restricted flow is the most common
Mar 05, 2017 | Hayward Pool & Spa
My Hayward H400FD is showing a H5 or HS error code, what does this mean, and what do i need to replace?
HS represents a problem with the temperature being too high. (maximum return water temp exceeded). this can be caused by a restriction in the plumbing system. i have that problem when i start my pool after a cold night. the water temperature rises too fast and the heater protects itself by flashing that code and turning off. reset the power to unit and it should work ok. if not, you may have to dig deeper as to why this code is being generated
Oct 02, 2014 | Hayward Pool & Spa
What does this mean Hayward pool heater h150FDN gives us an hs or h5 error?
HS = High Limit Sensor
Heaters Maximum Water Temperature has been Exceeded.
A few reasons this occurs...
  • Low water flow thru heater, check :
    • Dirty Filter
    • Opened By Pass Valves
    • Plugged pump impeller
    • Dirty/Full baskets at skimmer or pump
    • Anything that may reduce water flow
  • Sensor could actually be doing its job, in a different aspect, Thermostat failure, and water is overheating in spa or pool?
But anyway, your heaters fault code you asked about is: hs, not h5
May 17, 2014 | Hayward Pool & Spa
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
Pf hayward error code on gas heater H250 IDPL1
check pressure switch if voltage both sides ok if not bad switch or clogged copper tube also check filters
Nov 16, 2011 | Hayward H-series Electronic Gas Pool...
Hayward GAS HEATER KEEPS GIVING ERROR AO blower vacuum switch error? is this an electrical problem or does it mean the switch went bad, what do i look for?
This means that either the switch is bad, the wiring is corroded, the fan is not working, or the air switch tubing is broken or cracked. Follow the air switch tubing all the way to the end, remove it and check for cracks. This is the most common. Also check wiring connections for breaks, or corrosion.
If all looks well, replace the air switch.
Also, before any of this, make sure the fan is coming on at start-up.
Jan 16, 2011 | Hayward 400fdn Low Nox Nat Gas Swimming...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H250K gas pool heater error code
Low Flow errors are not necessarily real. They can be caused by improper adjustment or a defect of the pressure switch. Locate the pressure switch. Verify that the "switch" makes contact. Adjust the dial, reducing the distance the switch has to travel to engage. This will effectively lower the operating pressure required to operate. Keep adjusting until the unit stays on.
May 27, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Pool & Spa Logo
6,082 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
